Old 09-01-2009, 06:40 PM   #1
65ChevyUtah
Th400 & 205 transfer case what years ?
I am new to the 4x4 world I am putting my 65 chevy on a 77k20 frame. I have a
Th400 2wd trans that I want to use. In my research I found that the some of the 205 figure 8 style transfer cases use the 2wd th400. Does any one know what years of trucks I can find a 205 32 spline transfer case setup for the 2wd th400 ?
Thanks.
Pick N pull is having a half off sale this weekend so I am hoping to find the right one.
65ChevyUtah is offline   Reply With Quote
Old 09-01-2009, 10:33 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Th400 & 205 transfer case what years ?
Any 32 spline 205 will work with the 2wd TH400 as long as you have the adapter that goes with it.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 09-02-2009, 09:10 AM   #3
b454rat
Measure the output shaft sticking out of the tranny. If it's 6.5" then you use the adapter and case off an early 400/205. 84 and older.
All 1980 Gm trucks that are 4wd will have a 205, so find a 3/4 or 1 ton, long as it's an auto.
After 80', only 1 tons will have the 400/205. Prior to 80', 3/4 and 1 tons will have it, but can't remember how far back. Think it's only to 77/78.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 09-02-2009, 10:52 AM   #4
martindc1
Advance adapters sells various coupler sleeves to mate the various np205s to various transmissions. For instance I think they sell a 32 spline to 10 spline coupler sleeve.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 09-02-2009, 12:30 PM   #5
ghettoluxury
as long as the adapter is for a 400/205 and it mates to the 205 you have than it will work. so if you are going to a pick-n-pull than just make sure the tranny u pull it from is a 400
Old 09-03-2009, 02:23 PM   #6
65ChevyUtah
Good News ! I found a guy selling a 205 for a th400 for $200. I bought it and hooked it up last night. Bolted right up. Thanks for your help.
Old 09-03-2009, 08:06 PM   #7
ghettoluxury
Not a problem, that's why we are here.
Old 09-03-2009, 11:02 PM   #8
65ChevyUtah
well I tought I was on the home stretch on this project but It appears that the transfer case sits to lower using the original 205 crossmember. I thought all 205 crossmembers where the same ?? how to I do I get it to sit about 3-4 inches taller ? Is there a different crossmember i need or different mounts ?
Thanks again.
Old 09-04-2009, 02:10 PM   #9
OrrieG
OrrieG's Avatar
Can't you slide the crossmember you have up the frame, trim the top side flanges and drill new holes? If not maybe a piece of 2, 3 or 4" steel tube with trans mount to fit. Bolt bottom the cross member, top to mount and you are ready to go.
OrrieG is offline   Reply With Quote
Old 09-04-2009, 06:20 PM   #10
65ChevyUtah
Thanks for the help I think that would work for the length but the other problem I have is where the front drive line connect to the transfer case it is to close to the crossmember.. I may just have things jacked up. I'll take picture and post when I can.
Old 09-23-2009, 11:32 PM   #11
H8tulooze1
H8tulooze1's Avatar
I had my NP205 machined for the TH400 output, I broke a couple of adapters and now it holds together just fine.
1967 Nova SS LS9 900HP
1965 Malibu SS Convertible F/S
1965 Chevelle 2-Door Wagon F/S
1972 K5 Blazer 5.3
H8tulooze1 is offline   Reply With Quote
Old 09-24-2009, 04:45 AM   #12
68K20 x Drill
there are tall and short TH400 adapters, each with its own crossmember. I'm not sure which trucks came with what, but the difference is 2 1/2 - 3 inches.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 09-25-2009, 02:08 AM   #13
Dooley
Dooley's Avatar
"Prior to 80', 3/4 and 1 tons will have it, but can't remember how far back. Think it's only to 77/78.
All GM light duty trucks with automatic transmission from 1974-1979 had the 203 transfercase as standard equipment.
Dooley is offline   Reply With Quote
