Old 05-20-2002, 09:25 PM   #1
Benrs86
Benrs86's Avatar
Post rear end seal?
my dads 96 dodge 3/4 tons brakes are locking up in the back, last time this happened it was rear end fluid leaking out, and it would make them lock up. he told me to change the seals, and it is a floating rearend. this should be pretty strait forward. take of the wheel, take out the 8 bolts, slide the axle out, and take the seal out and put the new one in, right? any advice before i do this little project? thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
