Old 01-13-2003, 12:48 AM   #1
tkeduk8r
tkeduk8r's Avatar
250 cyl head????
welll i decided to pul my head off today after seein some moisture in my oil, and since my head gasket looked good i was gonna bring the head up to my machinist and have them go over it.... so my question is... if i leave the lower end as it is (its a 74 250), how much can i mill the head to get bout 9-9.5:1 compression, up from the stock 8.0???? figure as long as im there may as well do it... might help effeciancy and milage a little bit.... thanks in advance..
--mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 09-24-2024, 09:26 AM   #2
D'Monsta
D'Monsta's Avatar
Re: 250 cyl head????
It's 2024 and I am in the same predicament.. Anybody out there know an answer?
D'Monsta is offline   Reply With Quote
Old 09-24-2024, 09:40 AM   #3
leegreen
https://www.inliners.org/ubbthreads/...t&Number=68506
leegreen is offline   Reply With Quote
Old 09-24-2024, 09:55 AM   #4
Ziegelsteinfaust
Becareful how much you mill.
You may end up needing new push rods to go with it.
Ziegelsteinfaust is offline   Reply With Quote
Old 09-24-2024, 10:24 AM   #5
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
You will never get to that compression ratio with the stock pistons.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 09-24-2024, 02:07 PM   #6
theastronaut
theastronaut's Avatar
To figure out how much to mill to get a certain chamber volume, use a graduated cylinder to measure out that many cc of water (add a drop of dish soap), level the head, add that water to the chamber, then measure down to the water level.
Not sure, but there might be thinner head gaskets available that would also help bump the compression up. If you can find them, flat top 307 pistons work great to bring compression up.
theastronaut is offline   Reply With Quote
