09-01-2009, 09:30 PM | #1 |
1/8" drill bit broke off in manifold hole
replacing stud bolts on 402 big block exhaust manifold. Any tricks to drilling out broken off bit in exhaust manifold hole it had to be the hole that didnt go all the way through ,just tapped into manifold.
09-01-2009, 09:39 PM | #2 |
Re: 1/8" drill bit broke off in manifold hole
Dads71,
Dealing with these old manifolds can be a pain. I just pulled and replaced the studs on my manifold and had to drill all three out on one side. You're almost guaranteed a struggle. were you drilling out to tap size, or were you getting the pilot hole started? Zach ps i'm in princeton, in. Nice to see someone from the area. |
09-01-2009, 09:58 PM | #3 |
Is it a cheap carbon type bit? if it is you can heat it up till its really hot and then shoot it with cool air. It will shatter into small pieces.
09-02-2009, 05:15 AM | #4 |
Hey indiana k5 this was my pilot hole the stud is 3/8. never heard of heating it up and shooting air on it worth a try ,the bit isnt a cheapo I think index was 150.00 or so thanks for info.
09-02-2009, 07:36 AM | #5 |
i always just take a drift punch and large hammer to breakup drill bits
09-02-2009, 08:00 AM | #6 |
I would use an easy out with lots of patience...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-03-2009, 01:40 AM | #7 |
weld a nut to the stud, the heat will help release the stud/mani grip.
if all else fails i have some original 70 402 no air tube manis that i dont need. |
09-03-2009, 01:53 AM | #8 |
X2
I broke the old bolt heads when I rebuild my motor. they swelled inside the manifold sleeve. I had to heat them up and pry on the manifold to get clearance to stick a saw inbetween the head and the manifold and cut the bolts by had... what a pain that was. Welding a nut is awesome if you have the clearance. |
