Old 09-01-2009, 09:39 PM   #1
Legolas894
Chemist under the hood...
Legolas894's Avatar
Installing gauges on the 283
I'm tired of the idiot lights and don't have the money for a new dash with gauges. I bought a Sunpro Trio (Volts/Temp/Press). I think the temp and press are mechanical. Instructions are almost useless.
I have found the pressure "switch" on the top of the engine at the back next to the distributor. I assume you take the switch out and then put in the nylon oil line that runs to the oil pressure gauge. On my 283, I can't find anywhere where the temperature sender would be. My idiot light wasn't hooked up when I bought it. There was a broken gauge sender in the water outlet so I bought a new switch for that location. Post on here say there should be a spot near the spark plugs where the idiot light sender was supposed to be-I can't see anything there. I dont' really want to put the temperature sender in the outlet pipe since it's on the other side of the thermostat. Any ideas?? A picture of a 283 with the senders would be greatly appreciated....
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 09-01-2009, 11:41 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Installing gauges on the 283
First off id replace that nylon with copper and call it a day. As far as the water temp guage between plugs 1 and 3(the 1st 2 on drivers side0 there should be a plug in the head and on the passenger between plugs 6 and eight( back 2 cylinders0 there should be a plug..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-02-2009, 06:43 AM   #3
Legolas894
Legolas894's Avatar
Thanks-I can't see anything between plugs 1 and 2. I'll check the back of the other side today.
Current fleet:
Old 09-02-2009, 09:06 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
I guess I should have said that is on a 350 id assume the 283 heads were the same.. If not you maybe able to locate the temp senor in the inrake manifold.
MEMBER #6377
Project "7DEUCE"
Old 09-07-2009, 06:27 PM   #5
Legolas894
Legolas894's Avatar
I took FrenchBlue72's advice and installed a copper line for the oil pressure port to gauge. I kept the old sender and installed a tee. See my pictures below:
http://67-72chevytrucks.com/vboard/s...d.php?t=361549
Current fleet:
Old 09-07-2009, 08:04 PM   #6
geezer#99
geezer#99's Avatar
Checked the pics. Not the best place to get an accurate temperature reading. That's on the return after the thermostat. Might not show any temp till thermstat opens. If no other spot it's better than nothing. Good to use a copper line for oil gauge.
Old 09-07-2009, 10:04 PM   #7
Legolas894
Legolas894's Avatar
Yes-That's my problem-Only place to put it for now.
Current fleet:
