![]() Join Date: Apr 2009
Tranny pan gasket replacement
Well I am going to replace the tranny pan gasket this weekend, it is leaking a bit, and I looked under the Burb to get a look and it seems like the front pan bolts are under the crossmember. Can I reach these with a swivel socket? Any tips on getting these out?
I hope I don't have to take out the tranny to replace a pan gasket. Doesn't look like a lot of room, but just wondering. Also, is it worth getting a new aluminum pan rather then using the original steel pan. I have read previous post and it seems that people that have replaced with a nice aluminum pan had less issues with leaks. 350 tranny. Thanks |
Re: Tranny pan gasket replacement
I use a 1/4 drive swivel socket and it fits right up in there. I replaced my pan at the same time with a aluminum pan with a cork gasket and have been leak free for 3 years.
Sounds good hayhauler71. Thanks for the feedback.
its all about the +6 inches
1/4 in drive with a swivel.
if its still a pain, you can unbolt the tranny mount and lift the back of the tranny with a jack. |
I hope you are doing the screen filter too. I've never dropped the pan without replacing that while I'm there.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
make sure when you have the pan off to check the flange where the bolt holes are . they tend to disform due to over tightening and causes many leaks
do not overtighten only 12-15ftlbs of torque on those bolts i too lift the tail of the tranny up a bit for better access
Thanks for the torques specs.
I will be replacing the screen filter also. Came with the new gasket. |
very simple job, definetly get your self an aluminum pan...here is a picture of mine...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Thanks big_al_71. Kind of hard to see your pan with all that dirt and oil on engine and tranny. You really should clean that up a bit
![]() It looks like you are running a deeper tranny pan then the stock one. Maybe it is just the photo. |
Like a Rock!
Al, did you use a different trans cross member to make the deep pan fit?. I tried once with stock cross member and a deep pan wouldn't clear.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() Last edited by c10crazy; 09-02-2009 at 09:49 AM. |
Alum pan seals better due to the thicker more rigid flange. Can get one cheap on Ebay. That's what I have and it workes fine. Also came with a rubber seal which seems to seal better than the cork ones I've used in the past. I sprayed some high tack on everything to make sure it seals.
I am a Referee of life.
Deeper pans also tend to hold a bit more fluid and usually are finned to disapate heat better.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#13 | |
Yes you are right damn thing is super dirty!! Lol It is a deeper pan and it hold two extra quarts...
#14 | |
I used the tubular tranny crossmember from CPP and there was zero issues with clearances...
