Old 09-01-2009, 11:14 PM   #1
Livrat
Member #1049
Livrat's Avatar
1972 Rochester 2bbl Carb
factory for a 1972 with a 2BBl.. looks fairly clean. has fast idle solenoid still attached.. No idea on working condition, pulled it off of a dead engine. will probably at least need a new gasket kit.. $40.00 shipped
Livrat is offline   Reply With Quote
Old 09-03-2009, 09:30 PM   #2
lo72
Truck Junkie
lo72's Avatar
Re: 1972 Rochester 2bbl Carb
are either of the carbs in your post 2Gs
lo72 is offline   Reply With Quote
Old 09-04-2009, 12:06 AM   #3
Livrat
Member #1049
Livrat's Avatar
they are both 2GV's...
There are three basic 2 Jets. the differences are the 2G's use a remote manual choke.. the 2GV's used a thermostatic choke and the 2GC's used an integral automatic choke..
Old 09-04-2009, 08:07 AM   #4
72swbcamo
Active Member
I'm interested will you take $35.00 shipped.
72swbcamo is offline   Reply With Quote
Old 09-04-2009, 08:34 AM   #5
lo72
Truck Junkie
lo72's Avatar
I would need three, with at least 1 that has a thermostatic or automatic choke.
Old 09-04-2009, 12:31 PM   #6
Livrat
Member #1049
Livrat's Avatar
72swbcamo Yes, I would take $35.00 shipped
lo72 sorry, I only have the two.. both have the thermostatic chokes. Sounds like your putting together a tri-power set up?
Old 09-04-2009, 12:59 PM   #7
lo72
Truck Junkie
lo72's Avatar
yeah that is my plan. i have 2 of the carbs but the fuel inlet is on the front not the side...
Old 09-04-2009, 03:44 PM   #8
72swbcamo
Active Member
Livrat: Do you have the choke assembly from the manifold? If yes how much and how do you want for it. How do you want to get paid, is a money order OK?
Old 09-04-2009, 10:15 PM   #9
Livrat
Member #1049
Livrat's Avatar
Sorry I do not have the thermostatic coil assembly for the manifold... A money order is fine for the carb... PM Sent
