GEARHEAD
hard top mounting question
All the blazers/jimmys I've had so far came with single wall tops. So I'm familiar with how they are bolted in. But the yellow tub I bought for my 2wd came without a top, and the bed rails just have holes, no threaded plates. Is this how the double wall tops were set up normally? If I want to use a single wall top, do I just need to use nuts and washers then to bolt it down?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
Back in the sticks
Re: hard top mounting question
Right, double wall tops bolt up from the bottom, there's a strip inside the top with captive nuts for the bolts to thread into. If using a double wall top, I'd run a tap through the holes to clean them out real well prior to. Can't remember if they are 3/8 or 5/16 though. Someone else on the board will know for sure tho.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
GEARHEAD
Thanks for the info. So it looks like I can use either top easily enough.
I believe the single and dual wall tops bolt holes are in different locations, so you would have to drill new holes for the single wall top
PROJECT 7DEUCE
![]() Join Date: Dec 2002
They do bolt on on different locations on the bed rails.. I use carb studs to bolt on my double wall top...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I Love Rusty Chevys
I saved this off a previous thread:
5/16 coarse thread I believe 18 thread. You can drill and tap to 3/8 if you need to.
1969 K5 Blazer 1997 1500 Silverado Ext Cab Z71 2010 1500 Silverado Ext Cab Z71 Last edited by Otsa580; 09-02-2009 at 07:33 PM. |
