resident oilfield trash
Replacing metal brake line that runs across the rear end
Well I started this job like a good little mechanic with a Snap On tubing wrench. (I am working on the end that connects to the backing plate for the drum) When I rounded the flare nut off I went to a pair of 5 inch vice grips. Given the angle I cant really get a good bite on it. I have thought about cutting the line off with a cut off wheel and using an ease out but I feel like I might be opening a can of worms there. What have you guys done. I am ready to dive this thing and not having breaks is kind of a set back.
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 09-02-2009 at 02:25 AM. |
Re: Replacing metal brake line that runs across the rear end
You can try heat but I suspect that you are going to end up replacing the wheel cylinder.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Yeah, they are about $5, and if yours are rusted so bad you can't get the lines out, it may be time to replace.
Redefining LowBudget
heat or a new one just remember NEVER SIEZE you never know who the next JA to take it apart might be..maybe you...old man told me that and he has been right to many times
you might also try cutting the line off and putting a 6 sided socket on it....even if you have to goto a MM size and give it some love to get it on Last edited by Hottrucks; 09-02-2009 at 08:32 AM. |
more ideas than money
X2. A couple of $$ but a piece of mind.
![]() 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
2WD Jimmy
![]() Join Date: Mar 2005
Wow... Thats the first time Ive heard of a Snap On brand tubing wrench rounding off a fitting. Yea, Id replace the wheel cylinder. I wouldnt personally use anti-seize compound though... might not be good to use that on the hydraulic brake system.
Just cut it out and replace the wheel cylinder and rear tubing. You can get the tubing cheap and go to autozone for a flaring tool (free rental).
Or get a replacement line from a company/vendor (LMC, inlinetube etc..)
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 09-02-2009 at 08:53 AM. |
classic=of recognized value
I got my tubing from LMC and it worked well, just needed a few minor adjustments.
Oh i have new brake line. Thats why i am trying to take it off. Thanks guys. I really wasnt wanting to tear that drum apart. Dont have a whole lot of experience there but oh well have to learn some time.
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
Yeah thats why i spent 28 dollars on it
TOTY 2006
![]() Join Date: Dec 1999
You say you have new brake line, is it a prefabricated piece?
If not, and you are making a new line, please make sure you use double flare on the ends. When I redid my truck, I did not (just single flare), and when I bled the system, each single flare leaked. I had to remove all lines and double flare and reinstall..... Lessoned learned. |
#12 | |
#13 |
Just make sure you only take apart one wheel at a time so you have the other side to reference when reinstalling and a digital camera is your friend, take a bunch of pics during the tear down for reference later.
#14 |
Got er done thanks guys
#15 |
Funny to find this thread, I was just about to post a rear brake line question! On my 72 Cheyenne 4x4, I just replaced the left wheel cylinder. Putting on a new line I now find the wheel cylinder end is 3/16" and the end at the pumpkin is 1/4" Should I use 3/16" line and adapt at the pumpkin or use 1/4" line and adapt at the wheel cylinder? The factory line I removed actually had different fittings on each end. Thanks in advance!
#16 | |
#17 |
I cut the brake line with some dikes and used a socket to get the flare nut out. I wish I would have thought of that a week ago
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 09-02-2009 at 09:49 PM. |
#18 |
glad to help But be sure to never sieze it your only putting it on the threads not intoducing it to the system also PULL THE BLEEDS OUT and do them!!
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#19 |
Yeah it was so easy I just went ahead and did the other side
