01-13-2003, 02:02 AM | #1 |
i badly need help
i have checked and checked again for why my rear blinkers wont come on and why my brake lights wont come on though the taillights work when i turn them on, i have all new bulbs and fuses i have tested all the wires and they are hot but nothing happens what could it be
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
01-13-2003, 02:18 AM | #2 |
for the blinkers, have you used a test light to verify that you get a pulsing current to the bulbs...??? if not, start back-tracking til you do... the switch (in the the steering column) could be bad...
many lighting problems are also caused by poor grounding...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project Last edited by bigvinnie; 01-13-2003 at 02:23 AM. |
01-13-2003, 02:39 AM | #3 |
Brake & signal light are on the same segment of the bulb . Check the harness along the frame for damage , a pretty common problem .
01-13-2003, 02:48 AM | #4 |
Did you replace the flasher under the dash? Also check all your frame to body grounds.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
01-13-2003, 08:14 AM | #5 |
Old member
Lights
Check the connector at the back of the frame right before it gets to the last member. I had trouble with it before on mine. I had power all the way to there then nothing. You may also want to check and see if someone before you changed the wiring around. You never know why people do somethings.
01-14-2003, 12:23 AM | #6 |
its all about the +6 inches
Chances are your turn signal switch is bad. That or a couple wires are hashed.
01-14-2003, 03:23 AM | #7 |
Now the others dig........
Check the GROUND......GROUND GROUND GROUND.....Had a similar problem.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
01-15-2003, 12:21 AM | #8 |
Ground is not likely...possable, but again, not likely.
There is obviously already a good ground...the tail lights work, and they need a ground. There is only like an amp or two difference between the tail light and brake light. |
