help identify column
I am wanting to rebuild this column if it is a correct truck tilt. If it is a van of some other then I won't waste my time. How do you correctly identify a column? Total length, wiring, lower length? Thanks for any help.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
Re: help identify column
The length will tell you, shorter is a truck..
I don't know the correct length though, sorry. according to the tilt/turn levers it's period correct though. I'm rebuilding a van tilt, only issue is that I have to shorten the middle shaft in the engine compartment.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Looks like truck tilt to me.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
So the first thing I am hearing is that size matters. Sorry.
Kevsclassics, what tipped you off?
member #16
![]() Join Date: Dec 1999
A pic of the whole column will help. It looks like the rubber seal on the column is the truck type,also the wire connector. Wheres the N/S switch?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 09-02-2009 at 05:28 PM. |
Moderator
![]() Join Date: May 2007
x 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Need a better pic of the bottom of the column where the lower shaft bolts to it. The length of that will help determine which it is. Van is longer, truck and motorhome is shorter but the N/S on the motorhome is in the vans position.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
TILT COLUMN GURU
The 2nd pic is dark but I see where the intermediate shaft connects to the end of column is correct of a truck, plus the dash seal is for a truck. take a better pic of lower end of column so we can see location of nuetral safety switch and I can tell for sure.
