How to remove clutch pedal
My '68 was converted from a 3 on the tree standard trans. to a 200R4 auto. I discovered the clutch pedal still in there and hidden underneath the floor mat. Got the dash all tore apart and can see it real good but not obvious to me how to remove it. Any help appreciated. Thanx in advance.
Re: How to remove clutch pedal
There is a bracket on the right side of column support. Remove the pinch bolt & the bracket & slide the pedal & shaft out bto the left. I usually just whack em off close to the shaft but if you have the dash out & all it won't be to hard to remove.
I see what your talking about. Geeting dark, will do it tomorrow. Thanks a bunch!
send it to me/
