ls engine identification
i bought a 5.3 4l60e package and i was wanting to make sure its not a 4.8 how can i tell because the back of the block says 4.8/5.3
Re: ls engine identification
yep, the 5.3 and 4.8L use the same block. I believe the diffence comes from the crank only.
I would do some research on the heads. I would guess that the 4.8L use different heads than the 5.3L. This is assuming the heads haven't been swapped, but probably not. |
4.8 has a flat top piston and teh 5.3 has a dish....take the plug out and look in the cylinder with a flashlight.
There has to be a easier way than that.
