Old 09-02-2009, 04:49 PM   #1
Dan-K
Question Factory six-lug discs ?
I recently purchased what I beleive to be a factory six-lug disc brake set up. They were on a 72 Cheyenne super. I have also heard this was an option on some GMC.s as well. What would have come from the factory with this set-up ? and what year?
Dan-K is offline   Reply With Quote
Old 09-02-2009, 04:55 PM   #2
northerngmc
northerngmc's Avatar
Re: Factory six-lug discs ?
Was it 4X4? Because a 2wd 72 1/2 ton should have 5 lug disk brakes.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 09-02-2009, 06:38 PM   #3
Dan-K
It was two wheel drive. I really didnt believe him when I spoke to him on the phone but they are what they are. I thought they may have been old after-market but the calipers are G.M. marked.
Old 09-02-2009, 06:41 PM   #4
michael bustamante
michael bustamante's Avatar
calipers might be gm, but the rotors are definatly going to be aftermarket is the rearend 6 lug also?
1967custom
michael bustamante is offline   Reply With Quote
Old 09-02-2009, 06:43 PM   #5
BarryB
BarryB's Avatar
First to the board, BUT
Trust me somebody else would have done it, If I didn't.
Now seriously if you can post some pics of what your working with, I'm sure somebody can elaborate what you have. BUT like mentioned before. All the 71 72 I have seen are 5 lug disc brake set-up on the 1/2 ton trucks. and 8 lugs for the 3/4 ton trucks.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-02-2009, 10:11 PM   #6
powell72
powell72's Avatar
Welcome neighbor, all 71 and up 2wd half ton trucks had 5-lug disc brakes, no exceptions, regardless if it's Chevy or GMC. It sounds like an aftermarket rotor.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-03-2009, 10:24 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
bump
Old 09-03-2009, 11:09 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My ECE conversion from drums to discs is 6-lug. If I ever want to go to a 5-lug pattern, all I have to do is use the stock 5-lug rotors from GM or any other parts house. So, who's to say that someone didn't do the reverse and put some ECE (or other supplier) rotors on in place of the original 5-lug rotors?
Member Nr. 2770
Old 09-04-2009, 08:39 AM   #9
6-lug 2wd disc brakes aren`t factory.No pre-71 disc brakes/No post`70 6-lug.All 71/72s are 5-lug disc.All 67-70s are drum.
that`s the gospel.
Old 09-04-2009, 09:42 AM   #10
jorgensensc
jorgensensc's Avatar
THey definitely could have. If they changed out the rear for some reason,maybe they needed a new one and found a 6 lug rear, or they wanted the narrower track width on the earlier rears, and then they change over to disc brakes via a kit, then maybe they decided to stick with the 6 lug stuff.
Also, wasn't there a 'how-to' on using 88+ chevy 6 lug stuff for a conversion on the front? I could have sworn I read that somewhere. Maybe the previous owner used that stuff, that would say GM on it too. Just some ideas.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-04-2009, 09:58 AM   #11
westofb
I really hate wet sanding!
westofb's Avatar
I think I saw a thread on here where someone got the front suspension off of like a 88 or so 3/4 ton chevy 2 wheel drive and it was a 6 lug set up. I believe the 6 lug 3/4 ton was only available for a couple of years if I am remembering right.
westofb is offline   Reply With Quote
Old 09-04-2009, 10:59 AM   #12
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I believe '88-'98 Light Duty 3/4 tons all had 6 lug, Heavy Duty 3/4 ton had 8 lug.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-04-2009, 08:28 PM   #13
That`s a possibility...`88-up light C/20 parts.
Old 09-04-2009, 08:38 PM   #14
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
OK but the real ?? is how wide is it?? this maybe away to convert to disc and keep the skinny on things??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-04-2009, 11:08 PM   #15
texanidiot25
Eat My Rust
texanidiot25's Avatar
It's dirt easy to swap on the 73-87 heavy-halfton spindles, and with aftermarket 6 lug disks. There were no factory 6-lug disk 2wd trucks until the 88-97 era.
But, I run aftermarket 6 lug disks on 73-87 heavy halftone spindles/calipers.
texanidiot25 is offline   Reply With Quote
Old 09-05-2009, 12:42 AM   #16
tdave00
Restoring a 68 SWB
tdave00's Avatar
Yep. You have to use a C-20 lower a arm to make the balljoint fit that spindle. I have it bookmarked somewhere. I'll try and find it.
Edit: Linky
http://67-72chevytrucks.com/vboard/s...d.php?t=353393
That's not the exact thread I was talking about but good information.
tdave00 is offline   Reply With Quote
Old 09-06-2009, 10:25 AM   #17
Longhorn Man
however, back to the original poste's question, if your truck is a 2 wheel drive 1/2 ton truck, there is no way it has original 6 lug disks. GM didn't start that on half tons till 1999.
Old 09-06-2009, 08:43 PM   #18
Hottrucks
Hottrucks's Avatar
hey long horn has anyone tried to fit that spindle on to our old stuff..what kind of results if they did make it work??
Old 09-06-2009, 11:30 PM   #19
Longhorn Man
no idea what so ever. I have no interest in 6 lug discs, so i never paid any attention.
Old 09-07-2009, 07:15 AM   #20
It`s most practicle to just go ahead and buy the aftermarket discs and use knuckles that will bolt in,such as 71/72s.If you aren`t lowering you can buy someone`s cast-offs from their swap or,if you are lowering,buy the bolt-on kit.
Old 09-07-2009, 08:41 AM   #21
Hottrucks
Hottrucks's Avatar
being bagged and cupped I really can't go to dropped spindles I'm about as low as I can go unless I just want to have alower ride height but thats not what I'm after ...I just want to up grade to better brakes...I may just add power and run it
Old 09-07-2009, 09:21 AM   #22
I`d get someone who installed drop spindle`s original 71/72 spindle for very cheap to free,used 71/72 backing plates,rebuilt 71/72 calipers,new hoses,and aftermarket 6-lug discs.
