Old 01-13-2003, 05:30 AM   #1
magoo72
magoo72's Avatar
filler neck for frame mounted tank
where is the best location for a filler neck when you mount an under bed tank. mine currently is under my wheel weel above the rear tire ,but i would like to install a fuel door.any body out there done it or any other ways to do the job, please send me a pic of jobs that have been done and or any tips. mr magoo
magoo72 is offline   Reply With Quote
Old 01-13-2003, 10:09 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Hope this helps, its a fuel door out of a 73-87 style pickup or blazer, don't know for sure.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-13-2003, 10:22 AM   #3
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
71blksuper4x4, NICE TRUCK, I hope to do a 4x4 for my next project
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-13-2003, 11:07 AM   #4
71Seth
71Seth's Avatar
I dont remember where but I have seen the rear marker light hinged and used to conseal the filler neck. Very,Very smooth. I'll let you know if I find somthing. Help me out guys if youve seen this.
97 ext cab 4x4
04 pontiac grand am
05 honda rancher AT (yellow)
71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter
71Seth is offline   Reply With Quote
Old 01-13-2003, 12:18 PM   #5
my new 72
faster, faster, faster
my new 72's Avatar
I'm in the process of doing the filler behind the side marker thing now. Getting the hinged marker in was the easy part. Dirtdobber and I just finished fabbing up the filler tube using a filler tube from an 88 Buick Le Sabre. It will be all finished by the end of the week. It is a bit more entailed than tennman makes it out to be, as his is a 4x4 with a body lift, so he didn't have the clearance issues that us lowered 2wders have, but I am documenting the install, and will write up a full how to on the FAQ board when I am done.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 01-13-2003, 12:31 PM   #6
72MARIO
72MARIO's Avatar
The post about the taillight filler is at the paiont and body board
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-13-2003, 12:38 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Wes has this write up on his site
http://www.ClassicHeartbeat.com/mark...t_gas_door.htm
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-18-2003, 02:27 AM   #8
magoo72
magoo72's Avatar
i am currently in process of the job. i have my marker lite hinged and my filler neck in place. all i have to do now is cover the area in my bed side and floor. then the task of connecting the 2'' S-10 filler neck to the 1 1/4 inch tank filler. this seems like it is going to be a chore to stretch the 1 1/4 '' hose over a 2'' neck! is this goin to be possible? or is there some way to reduce the 2'' neck? any help will be helpfull.
today i installed my new inst. bezel, back w/ chrome edges,boy it is sure pretty! only prob. was when i got ready to back my truck out of my shop i had no oil pressure! guess what! oil line had broken in the process of mounting my manual choke! so i had a big mess under the hood OIL EVERYWHERE! i have come to expect these little errors with every inprovement i make. it seems with every project i do i have to fix something else that i messed up durin the job. o well! all part of the fun with working on these old trucks.
my planned paint time is still set for 2nd week in feb. during speedweek. i hope i will be ready. wish me well. good luck to all on your old trucks! mr magoo
Old 01-18-2003, 10:18 AM   #9
Zeke
Active Member
magoo72 I haven't done this but wouldn't an exhaust pipe adapter work? 2" to 1 1/4". If there was a way to put a bead on it so the hose won't slip off?
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 01-18-2003, 02:30 PM   #10
barn9
Half a bubble off!
barn9's Avatar
I've seen those adaptors made of rubber at plumbing supply stores, that could be another possibility.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 01-18-2003, 11:54 PM   #11
THECRAZYKIDJR
I USED THE FACTORY FILLER NECK FROM A 69 BLAZER. EMAIL ME AND I SCAN AND SEND YOU A PIC IF INTERESTED.
JIM PARKER
GLENBURN, MAINE
69 BURB 4WD - 307/4SPD/YELLOW
69 BLAZER (ORANGE / 35" SUPER SWAMPERS)
1970 CUSTOM-10
THECRAZYKIDJR is offline   Reply With Quote
Old 01-22-2003, 03:04 AM   #12
magoo72
magoo72's Avatar
today i finished off the filler neck part of the job. all i got left to do is box it in on the inside of my bed.
i wound up usin the filler neck i got out of the burb where i got the tank from. just had to do a little splicing to make the curves.i used a 8 '' 1 1/4 hose from a honda accord to make the connection. it was a booger gettin it all lined up,but that part is done
i went to the gas station and filled it up and no leaks! so i guess it was a successfull project. thanks to all for all your help. mrmagoo
Old 02-02-2003, 03:35 AM   #13
magoo72
magoo72's Avatar
pics of my job
this is how mine turned out
Old 02-02-2003, 03:40 AM   #14
magoo72
magoo72's Avatar
pic 2
Old 02-02-2003, 03:42 AM   #15
magoo72
magoo72's Avatar
filler up!
Old 02-02-2003, 03:46 AM   #16
magoo72
magoo72's Avatar
marker filler
Old 02-02-2003, 03:50 AM   #17
magoo72
magoo72's Avatar
first fill-up
Old 02-02-2003, 11:43 AM   #18
Piston
Piston's Avatar
Man thats got to turn some heads. Is it tough to get the gas cap off?
Looks like a clean install though. Nice job!
Piston is offline   Reply With Quote
Old 02-02-2003, 12:06 PM   #19
68 Stepside
huh?
68 Stepside's Avatar
Dude, you'd better get that scary guy away from your truck!! j/k of course That's a sweet arrangement, I've always liked the marker light filler idea...too bad I have a stepside...
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 02-02-2003, 02:52 PM   #20
72gmcshorty
72gmcshorty's Avatar
Anyone know how 71super4X4 got his gas filler hose to reach his tank? Thats where the filler is on my step side box and I was wondering how to reach a tank in theback. Any ideas?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 02-02-2003, 03:20 PM   #21
jay6891
Car Knocker
jay6891's Avatar
How well did it fill up? On mine I can't get the nozzel to the first click before it shut off automaticly. Using the 2" to 1 1/4" adapter. Maybe I don't have enough vent. I have got one , think I might have to unplug another? How many vents you got on your tank? Any suggestions, takes me about 30 min. to fill up.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 02-02-2003, 04:54 PM   #22
magoo72
magoo72's Avatar
no problems
the cap is low enough for easy removal. as far as filling it up ,i made sure that my hose had no kinks or any areas lower than the tank.if any areas in the routing of the hose are lower than the tank, or if it has kinks it will cause a back flow. the gravity flow must be correct or it will act as a ''p'' trap and will take a long time to fillup. not to mention the angry folks in line behind you !
Old 02-02-2003, 07:14 PM   #23
jay6891
Car Knocker
jay6891's Avatar
I don't think the hose drops below tank. Levels out when it goes between frame and bed support. I installed a lower radiator hose spring inside the hose to prevent kink. I will retry to get the angle of the dangle right, thanks, jay
Old 02-02-2003, 11:16 PM   #24
rayville body
what size is the filler neck on a blazer tank? i was thinking that maybe when i do the conversion to mine i could use exaust pipe since we have a muffler shop in the place i work. is it possible? i was thinking of using a filler door and the little hump thingy out of a 73-87 bed floor to get the clearance. has anyone done this?
rayville body is offline   Reply With Quote
Old 02-03-2003, 10:02 AM   #25
smokekiki
Mike
smokekiki's Avatar
Do you guys that have the filler behind the marker live where the pumps have bellows on them for pollution control?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
