09-02-2009, 08:59 PM | #1 |
disks installed which booster and m/c?
I installed disks up front on my 67 from a 72. The booster and m/c on there was already on the truck but both are shot. So do I get a 67 replacement booster and m/c or use set up from disk brake equipped truck? Please help.
09-02-2009, 10:25 PM | #2 |
Re: disks installed which booster and m/c?
should I use 67 master cyl. or 71-72
09-03-2009, 12:16 AM | #3 |
70 Chevrolet=Obsession
The 67 MC is a drum MC. The 72 MC is a disk MC with a larger capacity reservoir. I would very strongly recommend using 72 MC. The booster I'm pretty sure is the same for both disk or drum brakes. Find out what kind of booster the truck you got the disks from had. Be aware the GM offered both Delco and Bendix boosters for 71-72 half ton trucks. If it's a big pancake looking thing that's black, it's a Delco. If it's more cannister shaped and gold, it's a Bendix. Also, buy a new/rebuilt MC and booster. that way you know you have a safe braking system. BTW, I think you have to change out the old drum prop valve for a newer disk prop valve or an adjustable one. Sorry I'm spending all your money but you wanna do it right when it comes to brakes.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 09-03-2009 at 02:54 PM. |
09-03-2009, 01:26 AM | #4 |
Hollister Road Co.
You may also need a new prop valve for Disc/Drum
09-03-2009, 01:27 AM | #5 |
what else to you switch out to make the swap work?? thanks
68 C/10 short bed 77 C/20 silverado long bed 05 GMC Duramax Crew |
09-03-2009, 07:28 AM | #6 |
For disC brake swaps you want to get the master cylinder and proportioning valve to go with the calipers.
09-03-2009, 02:58 PM | #7 |
Make sure you get the right length pushrod that goes between the MC and the booster.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
09-04-2009, 09:01 PM | #8 |
So if I get a replacement booster which is a bendix style on my truck, the pushrod should be correct? Then get a disk brake m/c and my only worries should be the lines goin in to m/c and if the prop valve is correct. How to tell if prop valve is working properly? I also looked at autozone boosters are all the same between years.
09-04-2009, 09:38 PM | #9 |
I also noticed that the booster mounting brackets are longer on the disc brakes than the drums. I think they are about 5 1/2 inches long and the drums are about 3 1/2 inches.
09-04-2009, 10:41 PM | #10 | |
09-05-2009, 10:20 AM | #11 |
Here are some pics
they left is a Delco the right is a Bendix You can get a new replacement master cylinder with an adaptor piston rod to work with manual or power brakes. We sell them. We also sell New Delco style boosters. Last edited by mbgmike; 09-05-2009 at 10:20 AM. |
09-05-2009, 10:45 AM | #12 |
Good to know. I made mine using part of my original & part of the one from the donor truck.
09-05-2009, 02:28 PM | #13 |
thanks for all the help and advise. I let yall know what happens.
09-06-2009, 12:55 AM | #14 |
