Old 09-02-2009, 09:15 PM   #1
gmcdude
gmcdude's Avatar
New bumper install problem
I have this 72 GMC Truck, when I got it there where no bumbers or other items installed yet due to the pervious owner quit the rebuild. so thats where I came in. I ordered a new bumper and new brackets, I'm having trouble getting the brackets , I've bolted the bumper to the frame and as of right now the driver's left side seems to be real close to the frender compared to the other side. as for the brackets does the oblong hole go to the bumper or frame, and does it bolt to the frame in the front hole or back hole? Help Please
gmcdude is offline   Reply With Quote
Old 09-02-2009, 09:25 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: New bumper install problem
Not to put a damper on this, but I had the same issue....have you checked the frame??....my frame was bent!!!....had to take it to a frame shop to get her back in order...$300
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-02-2009, 09:28 PM   #3
gmcdude
gmcdude's Avatar
I was hoping it was'nt that but thinking was it also.
Old 09-02-2009, 09:41 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Forgot to mention...my truck was all back together before we noticed it....it maybe a little cheaper if you haven't install all the panels yet.....
If that's the case, you may be able to take a few measurements to verify...TO measure, I think I read right rear frame rail to left front frame rail and visa versa....measurements should be pretty close??...
Geoff with a G
Old 09-02-2009, 09:45 PM   #5
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
geoff is correct, measure the frame from opposing corners to make sure it is square. (if possible)
how do all your body and core support mounts look?
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 09-02-2009, 09:48 PM   #6
gmcdude
gmcdude's Avatar
Everything else looks good so far. I'm going to check with friends that has a shop.
Old 09-03-2009, 12:30 AM   #7
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
The oblong hole on the outer brackets go to the frame. (I know because I just put a new bumper on my truck) If your front frame horns aren't bent too much you can compensate with large washers between the bracket and the inside of the bumper.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-03-2009, 08:29 AM   #8
gmcdude
gmcdude's Avatar
Thanks it's not bad, I may be able to use washers.
Old 09-08-2009, 04:39 PM   #9
SOON2BLAZE
SOON2BLAZE's Avatar
Is it a coil or leaf rear suspension?
SOON2BLAZE is offline   Reply With Quote
Old 09-08-2009, 09:14 PM   #10
gmcdude
gmcdude's Avatar
coil front, lesf rear
