gas tank relocation FI
im about to run a 5.3 4l60e setup and i want to stay fuel injected. what routes can i do. i know fuelcellguy sells a tank but i dont really have money to spend 700 on a tank but it is a option. My question is what other tank can i go with that isnt as pricey. Also do i need a in tank fuel pump or can i run a external. One last thing as far as fuel lines go and fitting does anyone have the part numbers?
Re: gas tank relocation FI
When I read the title I was all ready to suggest FCG, but you have obviously already looked into that. If you change your mind, I think he is still offering free shipping.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
ya i love the design and everything alot of ppl are running his tank. he really does good work i will just have to wait i suppose i was just trying to rig something up for the meantime basically
You could run your in-cab tank with an external pump for the time being.
i'm gonna go with a ls1 equipped camaro/trans am tank. uses all factory components and can be had cheap......cheaper. look up ackattack's build in the projects/ builds section. he did a great job.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
Back in the sticks
Running a blazer tank on my TPI in the 71. Just run an external pump about 2 feet from tank on the frame rail, away from exhaust and whatnot. For fuel return, I just used the original vent lines and ran them back into one of the fittings on the tank. Have a vent on the tank with a length of hose to act as a vent pointing up, coiled and then the filler and vent for it. Works great.
I started out using the in cab tank, but the fumes were awful from it sending fuel back to the tank. You can make anything work with duct tape!!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
