09-03-2009, 12:08 AM | #1 |
Sb 400 club
th350/np203 to sm465/205 swap questions
Okay as some of you know from my other threade i got a screaming deal on a rebuilt Sm465/twin sticked np205 combo. I want to swap this sonn but relistically I will prob do it this winter when back from school.
Truck spec: 1977 K10 10 bolt front 12 bolt rear atleast 4:10 gearing. Short bed curently a 350 th350 np203. running 4 inch lift with 31's on the street and 34x 10.5 swamper tsl offroad. Parts I have: Sm465 5k on rebuild 10 spline output Np205 10 spline with ORD twin sticks (fixed yoke) sm465 to Np205 mounting bracket sm465 to np205 spline sleave Hydro clutch bellhousing clutch fork flywheel Clutch pedal Trans mount bushings Blaze rear drive shaft Parts needed: Clutch kit Front drive shaft?? Rear drive shaft?? Crossmeber?? Slave / master/ lines for clutch (I can get this from NAPA) Questions...... Will any of my current drive shafts work?? I know i will need to move the cross member drilling new holes in the frame but will np203 crossmeber work?? What year used the hydro clutch bell housing so I can order the right master and slave? Any other input on the swap would be very helpful. I read the write up on CK5 and that will take care of my pedal mounting isssues. Thanks
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
