Old 09-03-2009, 08:34 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
ECE- C-20 ¾ to ½ Ton Conversion Spindles
Recently I have seen a trend toward ’60-’70 model C-20 trucks being upgraded from stock drum brakes, lowered, etc. The common suggestion has been to convert to later model suspension which required replacing a lot of the current C-20 suspension. Considering the age of most of those components thats not a bad thing to do.
Eearly Classic Enterprises has announced they are now offering C-20 ¾ to ½ Ton Conversion Spindles. This allows you to either a 5-lug or 6-lug bolt pattern. These new Conversion Spindles allow you to upgrade to C-10 front disc brakes on the ’60-’70 model Trucks, and give you the option of stock or 2½" front Drop Spindles for the same price without having to change your tie rods and ball joints.
Check it out- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-03-2009, 09:01 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: ECE- C-20 ¾ to ½ Ton Conversion Spindles
And the best part about these spindles is that it allows you to use original C20 balljoints and tie rod ends.
Even if you are replacing all of this,... the C20 lower control arm is different (larger ball joint hole),... so there is no need to swap out the lower control arm to switch to 1/2 ton brakes.
Keith
Convert to disc brakes.
Old 09-03-2009, 10:18 AM   #3
Ackattack
Ackattack's Avatar
I saw these and may use them for Project No-buck.
Ackattack is offline   Reply With Quote
