Damn Yankee
1962 Suburban rear bumper
Is the 62 Suburban rear bumper actually a front?
Shloooooong bed member #2
Re: 1962 Suburban rear bumper
They look to be real close. I think the rear actually wraps around a little bit further. But I think the bracket mounting holes are same.
The stlye for both is the same. the rear does not have the cut out for the licence plate.
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Other than the hole spacing they are the same. Keep in mind though that the front bumper hole spacing is different between the '60-'62's and the '63-'66's. As for the rear bumper hole spacing I would have to verify if they are different in those same year groups.
On building my 66 Burb I found the rear bumper bracket and holes are different from the front. Therefore I am looking for a rear bumper to finish my 66.
60-66 Nut
I measured my '60 GMC 4x4 Suburban frame at the rear and it is wider than a '63-'66 Suburban/Panel frame at the rear. So it appears that the '60-'62 Suburban/Panel rear bumper hole spacing is different than for the '63-'66's.
