? for swervin ervin
What is the diameter of the ducting going to your ram air set-up? What do you do as far as emissions related inspects because the vac actuator flaps & hot air riser were eliminated? Thanks, Scot
Im not Swervin Ervin, but I might be able to help.
Im not 100% sure, but I think they are 4" diameter (I.D.). He kept his original air cleaner assy. and puts it on for inspection.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
That was my guess.
You get what you pay for
![]() Join Date: Dec 1999
Eddie is right, it is 4". The first year I had the Ram Air, I put the old air cleaner back on for inspection time. The last two times, I didn't bother and he passed it anyway. As strict as they are around here, go figure.
Mike 1985 Chevy C-10 |
