09-03-2009, 12:28 PM | #1 |
Valve Cover Question
Happy Labor Day early to you all Have a question on an early 235, will a 216 valve cover fit a early 235 ? I took mine off and found the bottom of the inside covered with rust from sitting for years. It has the two holes in the center of the cover with the o rings around the studs......Thanks
09-03-2009, 01:29 PM | #2 |
Re: Valve Cover Question
I have a 58 - 235 valve cover on the engine that is going to be scrapped. I can look at it tonite to see if it is clean.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 09-03-2009 at 01:30 PM. |
09-03-2009, 01:52 PM | #3 |
Thanks Orrie, Where are you located ? I am in LaGrande aera above Boise.
09-03-2009, 06:36 PM | #4 |
In Boise, older neighborhood right below the airport.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
