Old 09-03-2009, 12:34 PM   #1
abilityonline
67-72 temp gauge question
I replaced my 68 c50 radiator with a modern rad from a F350. My temp gauge never worked, however I noticed the wire just hanging with a clip on the end. It has to be to the temp gauge. Where does this clip on? On the wiring diagrams it shows it going to the rad cap. Is that correct?
abilityonline is offline   Reply With Quote
Old 09-03-2009, 12:57 PM   #2
SoCal71K20
Re: 67-72 temp gauge question
Goes to grounded temperture sending unit that is threaded into cylinder head or intake manifold or thermostat housing. Good luck.
SoCal71K20 is offline   Reply With Quote
Old 09-03-2009, 09:39 PM   #3
Legolas894
Chemist under the hood...
Legolas894's Avatar
My goes to the temperature sender in the water outlet cover. That's not too typical though. Most temperature senders are on the manifold I hear. Are you sure it's for a gauge and not an idiot light? If you put it to ground, the TEMP light should go on.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 09-04-2009, 02:15 PM   #4
abilityonline
Here is some pics. I'm positive the wire in the photo goes to the temp gauge because by grounding it it moves the gauge. I'm also sure of where it attaches. The bolt on the upper block next to the upper hose. My question is the end of the wire looks like it should plug into something.
Yes I need to clean it off.
Here is where the ground post is
How does this wire secure to the post? Should it plug into something or should I crimp another end with a ring style end that fits around the bolt?
Old 09-04-2009, 02:32 PM   #5
fixit-p
fixit-p's Avatar
It should go to a sending unit and not straight to ground look on the driver side head between the first two plugs should look somthing like this.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
