Old 09-03-2009, 03:01 PM   #1
bmfpeterson
bmfpeterson's Avatar
slop in front a arms
I bought some stock arms and front end parts from a guy on this site and it all came off a 67 1/2 ton. (I have a 71 half ton)
I got everything on and the rivet that hold the lower cross shaft in place is smaller than the hole in the cross shaft. when i tore all mine out i never really looked at it and wondered if that is normal slop or if it should fit tight into place. also i don't have the lower cross shaft u-bolts tight yet if that makes a difference?
I also noticed that the cross shafts for the upper arms are a little different as well. it looks like the shaft is bigger in diameter and where the nut would hold it against the frame the cross shaft is concaved a little instead of mine that are flat???(if that make sense)
any help is greatly appreciated!!!
bmfpeterson is offline   Reply With Quote
Old 09-03-2009, 03:42 PM   #2
bmfpeterson
Re: slop in front a arms
Ttt
Old 09-10-2009, 02:51 PM   #3
bmfpeterson
anybody.....somebody........bueller.....bueller????
Old 09-10-2009, 04:24 PM   #4
67cheby
67cheby
67cheby's Avatar
it is supposed to be concaved there should be part on the frame that is concaved the other direction so when you put shims in between in it smashes them together , as for the bottom it is not an exact fit there is a little room it will be fine when you tighten it up
67cheby is offline   Reply With Quote
Old 09-11-2009, 05:39 AM   #5
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Ive got mine 68 apart let me see if i can take a pic of the frontend to help alittle
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 09-11-2009, 01:24 PM   #6
bmfpeterson
thanks guys i appreciate the help... if you could get me a pic of that maybe I can find out what con caved part i am missing...
thanks
