Old 09-03-2009, 03:25 PM   #1
ges55
BLACK SATIN
ges55's Avatar
67 C10 power assisted steering box
Does anyone know where I can get one of these? My understanding is that in 67 & some of 68, the ram assisted steering was used instead of the integral type of power steering. I have a leak & the cylinder is scored pretty badly.
ges55 is offline   Reply With Quote
Old 09-03-2009, 03:54 PM   #2
dan42
dan42's Avatar
Re: 67 C10 power assisted steering box
Apparently they never really worked very well, and started leaking early in their lives. I installed a conventional power steering unit on my '67 and it works fine. I don't know of anyone that supplies parts for this unit because not many people have or keep them, but you might check the vendor list.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 09-03-2009, 04:36 PM   #3
mr48chev
mr48chev's Avatar
Unless you are just bent on using the original unit I'd suggest swapping over to the later box and getting rid of that setup.
The only issue outside of changing hoses from the steering unit to the pump is that you may have a slight clearance problem to deal with between the power steering box and the frame when you bolt the box up.
Old 09-03-2009, 06:27 PM   #4
tkmad
Does the later model box need a new pitman arm?
Is it the '76 and later boxes that were proportional?
tkmad is offline   Reply With Quote
Old 09-04-2009, 08:24 AM   #5
ges55
BLACK SATIN
ges55's Avatar
By later, do you mean the 68-72 steering box?
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
Old 09-04-2009, 10:56 AM   #6
tkmad
Yeah, does the pitman arm of the power ram setup from the '67 fit the '68-'72 boxes?
