Old 09-03-2009, 04:03 PM   #1
texanidiot25
Eat My Rust
texanidiot25's Avatar
throttle cables, where to buy?
Where can I buy a replacement throttle cable for a '69? Autozone, O'Rielly's, NAPA, none carry it. The O'Rielly's girl even looked into the old books and called a few venders and none carry that part number any more.
Need the one that snaps onto the ball stud of the carb, and then has a bare cable that attatches to the pedal linkage. And I'm not interested in swapping to a '72 throttle setup at this point.
texanidiot25 is offline   Reply With Quote
Old 09-03-2009, 04:22 PM   #2
john
member #16
john's Avatar
Re: throttle cables, where to buy?
I think you will be on your own if you want a cable,as 69's had a rod. Probably have to chop up a cable setup from a later truck.
john is offline   Reply With Quote
Old 09-03-2009, 04:31 PM   #3
texanidiot25
Eat My Rust
Eh? Then where did this come from?
This is what was on my cab when I got the truck years ago, and snapped right onto the ball stud of the carb.
Old 09-03-2009, 04:37 PM   #4
john
member #16
john's Avatar
Appearantly the P.O. hacked up a later cable.Good luck with it.
Old 09-03-2009, 04:41 PM   #5
texanidiot25
Eat My Rust
Strange... But when I've called up parts shops, they know exactly what I'm talking about (as the piece pictured above). The old guy at autozone (1st time I've had real help) and the girl at o'reilly's who went threw thier books said this is what they'd normally have if it was in stock. A cable that snaps onto a ball stud on the carb, and then is bare cable at the other end for the throttle linkage... maybe at somepoint they quit selling linkages and used this in their place for safety... I dunno.
Or any leads as to what that piece came from.
Old 09-03-2009, 04:43 PM   #6
nsuengineer06
nsuengineer06's Avatar
Try Lokar, they are expensive, but have lots of stuff.. Might have something that would work for your application.
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 09-03-2009, 04:49 PM   #7
texanidiot25
Eat My Rust
Not like this, I looked a few days ago. I need something cheap right now. Low budget daily driver, and saving up to do my cab swap. Just want a replacement so I don't have to run the clothes hanger linkage...
Old 09-03-2009, 04:54 PM   #8
LiMiT44
FYI
According to my LMC catalog 67-70 accelerator rod, 71-72 accelerator cable. It does list three cable, 350 2wd, 350 4wd, 402. The drawing is similar to your picture.
LiMiT44 is offline   Reply With Quote
Old 09-03-2009, 05:46 PM   #9
71 super
71 super's Avatar
Someone has modified your truck at some point. As others have said, rod from 67-70, cable in 71 and on. If you have seen the lift stop kits from GM, they were made as a recall as there was a real problem around 69 with motor mounts breaking and causing the throttle rod to stick at WOT. The lift stop was put on as a preventive measure to stop the accidents. The move to a cable was an attempt to prevent the problem later. Your 69 originally had a rod.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-03-2009, 09:14 PM   #10
Green Machine
Green Machine's Avatar
You can see that that plastic sleeve is not needed but the sleeve is used on an actual cable setup. You have just an end of a cable, grafted from something else.
Heres a plan - go to the parts board and get a linkage rod from a 70 or older with a q jet, they really did not use a cable, then remove the ball stud from the carb, and repalce it with this handy piece from Summit http://www.summitracing.com/parts/MRG-1512/. Tighten it on the rod and you are done. Thats what we use on the edelbrock carbs and it works great.
Or this looks great too http://www.summitracing.com/parts/MRG-3812G/. Just add a piece of threaded rod and you are good to go !
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 09-03-2009, 10:05 PM   #11
BCOWANWHEELS
my 69 and 70 both have rods and there factory 4 sure
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-23-2009, 02:48 PM   #12
rbeau30
rbeau30's Avatar
My '71 has a cable looks much like a bike brake cable, that comes out of a rod that houses the pull knob. The other end of the "Bike cable" goes directly to the gas pedal.
Quite rudimentary, but I guess it works. I told my girlfriend that if she is ever driving my truck to never pull it out. (horrifying scenarios come to mind)
Robert
1971 C20 SWB Fleetside undergoing an amateur restore.
rbeau30 is offline   Reply With Quote
Old 09-23-2009, 03:33 PM   #13
71tahoe
71tahoe's Avatar
I'm having a difficult time picturing this so:
71tahoe is offline   Reply With Quote
Old 09-23-2009, 03:42 PM   #14
rbeau30
rbeau30's Avatar
I'll post some pics when I get home from work Not to fear!
Robert
Old 09-23-2009, 03:43 PM   #15
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Nice... surfing the forums at work. LOL
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 09-23-2009, 03:48 PM   #16
rbeau30
rbeau30's Avatar
Yes! AND I am a government worker too! muwahahahaha!
Robert
Old 09-23-2009, 04:08 PM   #17
toddtheodd
toddtheodd's Avatar
They hiring in my side of the country?
I need a job like that.
IIOY???
Old 09-23-2009, 05:08 PM   #18
texanidiot25
Eat My Rust
I ended up going to the junk yard and sourcing another throttle cable that snapped on a ball stud. The yard owner didn't even know exactly what it was from, but he said look in old ford trucks. And it's where I found one
Old 09-23-2009, 09:03 PM   #19
71 super
71 super's Avatar
rbeau30 it sounds like what you are describing is a manual throttle. Is the knob mounted on the instrument cluster? If so do no pull it straight out, it is designed to twist out to set the throttle, if you pull it you can rip it apart and they can be sorta hard to come by.
Old 09-23-2009, 09:35 PM   #20
texanidiot25
Eat My Rust
Their rare? There's one in a '69 burb in my local yard. I thought it was some ghetto-rigged cruise control honestly.
Old 09-24-2009, 08:23 AM   #21
rbeau30
rbeau30's Avatar
Yes it is on the instrument cluster, I don't see many trucks or pictures of interiors on here with that option on it. It is on my SPID so when I start with the interior I am going to have to restore it with the throttle knob there.
It functions yes, I did notice that it twists, good thing when I was experimenting that I decided to twist it instead of pull it, it does look like it is sorta fragile. I'll put some pictures up today at lunch, yesterday it was raining like crazy here and wasn't able to get outside.
I guess I misunderstood the title of the thread. And you guys are discussing actuall throttle cables and not Manual Throttle cables.
Robert
Old 09-24-2009, 07:59 PM   #22
rbeau30
rbeau30's Avatar
Okay here are the pics: Yes it is a Manual throttle.
The first one is the dash cluster with the knob screwed out partially.
The second one is behind the dash cluster showing what the little stick thing looks like that the cable comes out of.
The third one is the cable where it attaches to the gas pedal.
The fourth is the whole gas pedal assembly with the cable attached to it.
It all reminds me to a bike cable that goes to a brake on the rims of the tire. LOL
Robert
Old 09-24-2009, 09:31 PM   #23
toddtheodd
toddtheodd's Avatar
Is that like... some sort of old fashioned cruise control?
IIOY???
Old 09-24-2009, 10:13 PM   #24
rbeau30
rbeau30's Avatar
You know what I was thinking is that it may be helpful to have it for starting in cold weather, maybe it would assist in cold weather starting or perhaps maybe would assist in an accessory that is attached to the truck that is controlled by the throttle speed.
Wierd.
Robert
Old 09-25-2009, 12:26 PM   #25
toddtheodd
toddtheodd's Avatar
Wierd.
I use my manual choke for the cold weather starts. It's aftermarket, but at the... chokage it likes, it's opening the carb a little bit and putting me right at about 1200 rpms...
I hate cold starts...
IIOY???
