Old 09-03-2009, 04:50 PM   #1
Reddog123
1964 Chevy Truck Motor Problem
My 64' Chevy truck -slant 6 motor started making a knocking noise when it started up. It is a noise I have never heard before. It sounds like metal on metal. Does anyone have an idea what this could be, before I start tearing down the motor?
Reddog123 is offline   Reply With Quote
Old 09-03-2009, 05:03 PM   #2
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: 1964 Chevy Truck Motor Problem
Tinny sound? Banging sound. Low-Thumping sound?
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-03-2009, 06:37 PM   #3
Oregoon
Roadside Rebuilder
Oregoon's Avatar
If you have a slant six, you have a Dodge. That's a problem.
Seriously though, I imagine you have an inline-six, and metal on metal noises can be anything from a loose fan to a spun rod-bearing. Is it clunky, or scrapey sounding? Does it go away when you give it fuel, or get louder? Are there metal shavings in your oil, or on your drain-plug? Is there water in the oil, or vice-versa? Does anything feel loose?
Take a stethoscope (with a rag wrapped around it), or a piece of rubber tubing, and listen to different places around the motor, to see if you can determine where it's coming from. That's often a good start.
Oregoon is offline   Reply With Quote
Old 09-04-2009, 06:18 AM   #4
5264chevytrucks
I had my 64 crack piston 6 and 4 and the noise I heard was pieces bouncing around. Of course, I had smoke coming out the tail pipe too.
5264chevytrucks is offline   Reply With Quote
Old 09-04-2009, 10:34 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
Grab the fan and see if it wiggles. If so the bearings in your pump are bad.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-04-2009, 10:51 AM   #6
MacAttack
283 Drama Queen
MacAttack's Avatar
If it's an automatic transmission - check the flex plate. Sometimes, if the fan belt's be over-tightened you can crack the long-nose pulley too. If you hit something on the road - you might want to check the transmission cover.
Old 09-04-2009, 12:43 PM   #7
Muleman100
Muleman100's Avatar
I have never seen a slant six in a Chevy, only in Dodges. Yank it out and get a good 250 or 292 inline Chevy six.
Muleman100 is offline   Reply With Quote
Old 09-05-2009, 07:07 PM   #8
Oregoon
Roadside Rebuilder
Oregoon's Avatar
I've seen a slant-six swapped into an International, a Ford truck with a Duetz air-cooled diesel, a Willy's with a Toyota motor, and a Scout with a Pinto 4-pot... And I'd like to build a '60-'66 with an Isuzu Diesel.
Just sayin'.
