Old 09-03-2009, 07:10 PM   #1
rage777
rage777's Avatar
motor mounts
evidentally i need to replace my motor mounts, so i've been told. how much should this cost me? what's involved in replacing them?
1972 Chevy C10 Long Bed
454 Big Block
Turbo 400 3 Speed
Dual Flowmaster
Edelbrock 750 Carb
Power Steering
Disc front brakes
Drum rear brakes
B&M Floor Shifter
rage777 is offline   Reply With Quote
Old 09-03-2009, 07:41 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: motor mounts
If you are just replacing them, a floor jack and a few blocks of wood will do. You can do it one of two ways, either removing the bolts holding the mount to the engine or the bolt holding the mount to the frame bracket. With a floor jack and a block of wood, place it under the engine, more to the one side you removed the bolts and carefully jack up until you can get the old mount out. Swap in the new mount leaving the frame side bolt a little loose. Do the other side and after all the bolts are in, tighten them up.
Luckily these engine bays have a lot of room to work in, unlike a lot of newer cars/trucks.
Not really a hard thing to do but does take a couple hours.
Easy but more $$$ is take it to a shop and have it done.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-03-2009, 09:11 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: motor mounts
assuming we are talking the 72 big block in your signiture, they are cheap.
Old 09-03-2009, 10:25 PM   #4
Terakilla
Terakilla's Avatar
Re: motor mounts
Really simple fix, with your truck signiture thought you'd know, about the easiest thing to work on really.
Terakilla is offline   Reply With Quote
