Salty Sailor
i won the bet!
no more exhaust leaks and a noticable increase in power. what do yall think? here is a link to a video i put on youtube: and if you want you can hear it before the headers and before the dual exhaust in some other videos.
86 c-10 Custom Deluxe Savannah, Georgia |
Happy to be here
![]() Join Date: Mar 2000
Re: Got my new headers installed, my dad is now convinced
Not sure exactly what the bet was, but I wouldn't spend the winnings just yet. When your headers start to leak in a few months, he may want some of his money back.
Seriously, headers are a good upgrade. Unfortunately they are prone to leaking too.
#3 | |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
![]() Join Date: Jul 2009
^^^ Yepper. I have had several sets on different vehicles and they all seem to end up leaking
where did yalls leak. mine were always at the collector. Ive thought about using vbands. anyone have experiance with them?
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
On a budget like Fred Sanford
Quality headers with good flanges don't leak.
![]() BTW bucannon....your valve seals are leaking. ![]()
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 09-04-2009 at 12:24 PM. |
I have Hookers on my blazer and the bolts would loosen up on the flange every couple months. The only header I've never had leak is the one on my Harley!
I can still count my vehicles on two... wait three hands. |
Still plays with trucks
Use a set of the header specific small diameter lock washers and the longest bolts into the heads you can make work. Use copper high temp RTV on both sides of the gaskets.
After a day of driving go back and tighten the bolts again after the engine cools down. Do this the first couple times after you drive the truck until they do not need further tightening after a heat cycle. Once everything has seated and heat cycled a few times you shouldn't have any leaks unless you have cheap headers with thin flanges that warp from tightening the bolts down. |
My only experience with V-bands was on some turbo applications, and they were fantastic even under very high boost.
And, the last set of headers that I had...that leaked...was a set of Hooker Super Comps, and I did all of the recommended tightening. I even used the Stage 8 lock bolts and still had issues. But it was a motor swap into a ba$tard application, so that could possibly explain it... |
The last pair of Hooker Super's I had only had 1/4" flanges at the head and warped like nobody's business.
My Pacesetter's on the 98 have 3/8" flanges and seal perfectly. I am putting 1/2" flanges on the old Hookers on my 68 Camaro to fix the warping problem the lame 1/4" flange has. |
1975 C-10 Silverado LWB
my f**d came from the factory with headers and after 108k miles the headers still don't leak?
1975 LWB C-10 Silverado - Stock - "BIG 10" - 4 Bolt 350 "Brand new" 1200mi - THM-375 "Brand new w/trans cooler" 5000mi 1995 Ford Lightning - Bone Stock - 351W - Vortech?? |
#13 | |
If your headers leak you installed it wrong or the company who made them built them wrong. Last edited by Number21; 09-04-2009 at 08:51 PM. |
#14 |
^^^Pretty hard to install wrong...they are either in or they aren't. And they didn't leak immediately, but after a few thousand miles.
And comparing factory "headers" to an aftermarket header isn't exactly a fair comparison. But I will contest that the aftermarket ones tend to be hit or miss. Cheers!!! |
#15 |
#17 |
78 Big10 454
![]() Join Date: Jul 2008
An old gearhead taught me to soak the gaskets in water overnight prior to installation. No sealant necessary. Torque the bolts to manufacturer's specs and away you go. My headers are 28 years old and have yet to leak.
#18 |
Watchin the rust grow
![]() Join Date: Oct 2008
Leaks are so hard to detect where exactly they are coming from sometimes.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done ![]() 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
#19 |
86 C10
so wheres the pics of the headers installed?
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
#20 |
i have a pair of dynomax shorties on my elcamino, used manifold gaskets instead of header gaskets, and used bolts with a stop screw in the middle that splits the tip so it wont budge, and i have copper flange gaskets and for 2 years i have never had a leak
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
#21 |
Headers are definitely a great upgrade from the crappy factory manifolds. I've heard of soaking them in water too overnight. As long as you tighten them from the middle bolt outward, in steps (not as tight as you can get it on the first try), and go back and retighten them after a few heat cycles, you should be fine.
Usually, I'll check my header bolts among other things when I do an oil change because it gives me something to do while the oil is draining. $.02
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
#22 |
I have split the mounting flange between the separate tubes on several sets that leaked to allow an unevenly ground sealing surface to move a little when tightened down independent of the adjacent tubes.
Another way to stop leaks is to double up the composite gaskets or use thicker gaskets. The thick ones are pretty expensive but come out to about the same cost as two sets of the cheaper ones so it is a wash if both are available to you. I have used manifold gaskets with headers too. Sometimes it works sometimes it doesn't. I don't think they give enough to compensate for the inherent unevenness of the header mounting surface. |
#23 |
Salty Sailor
i used expensive dead soft aluminum gaskets and still after a month no leaks. i dont expect any either. but i want to hear some responces on how my truck sounds
#24 |
Salty Sailor
if you want to see pictures go to cardomain.com and look up the user 72satellite, you can see pictures of my truck with the headers as well as my 72 plymouth satellite project
#25 |
Doug Thorly try y's 3/8 flange never leak.
![]() Last edited by N2TRUX; 10-09-2009 at 07:45 AM. |
