Old 09-03-2009, 11:05 PM   #1
brawley
Easy Does It
brawley's Avatar
rear end swap?
Im looking to swap out my stock rear end for one with positive traction. It needs to be six lug. I've heard that the 73-87 Blazer would be a good canidate? What have you guys used that works for these trucks? thanks.
brawley is offline   Reply With Quote
Old 09-04-2009, 12:59 AM   #2
Captainfab
60-66 Nut
Re: rear end swap?
The differential from any K10 thru '87 as well as the '69-'87 K5 Blazer would be of the 6 lug variety. I'm not too sure just what they measure though compared to the '63-'70 12 bolts. As long as your current 12 bolt has the 30 spline axles, you can install a 'posi' carrier from any truck 12 bolt. Which were available thru '79 and some early 1980 models.
Swapping the entire differential from a K series can be done, but you will need to change the mounting pads if your truck has coils. Plus you will need to either transfer a panhard mount from a '63 or '64 12 bolt, or fabricate your own panhard mount
You can also go with an aftermarket 'posi' or locker.
Old 09-04-2009, 01:04 AM   #3
2tons of fun
Re: rear end swap?
the vast majority or 60-66 truck had posi's.
why swap out the entire axle when all you have to do is the carrier.
2tons of fun is offline   Reply With Quote
Old 09-17-2009, 09:07 AM   #4
brawley
Easy Does It
brawley's Avatar
Re: rear end swap?
It seems hard to find a posi unit for the 63 & earlier rear ends, I've seen alot for 65' and up. Any body know where to look ??? thanks
Old 09-17-2009, 04:59 PM   #5
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: rear end swap?
the reason you would have to swap the whole axle is because 63-64 have 17 spline alxes, while most posi's are 30.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
