printing is my trade
Is this my oil sending unit?
Is that my oil sender?
If not is it in this pic? If so why is there 2 wires? Where do those wires go to?
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184 |
Re: Is this my oil sending unit?
If that comes out of the block behind the intake then yes it is an oil pressure sender. That particular one is for a oil pressure light though, not a gauge. It is just designed to turn on/off a light at some preset pressure setting. The one for an electrical gauge (not a direct pressure reading unit) is usually larger in diameter and down by the oil filter.
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S Last edited by jholley; 09-03-2009 at 11:44 PM. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looks like it could be but see that brass fitting in the upper right corner of the pic? Thats for the oil sender(mechanical gauge)
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
its all about the +6 inches
that looks like some one just shoved it into the intake to block a port... can you get a betterr photo, maybe where it is threaded into the engine?
#5 | ||
70 Chevrolet=Obsession
I'm gonna go with Longhorn man on this one. I'll bet the PO just used it as a plug.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 09-04-2009 at 02:53 AM. |
That's not in the right place, I can't imagine there is oil there, take it off and see if oil squirts all over the place.
it is being used as a simple pipe plug, it is serving no oher use at this moment and place.
Car Knocker
x2, if anything its screwed into a water jacket.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
I see how that pic looks like the plug is going into the intake but its actually not.Heres a better look at it (right behind the intake):
I disagree. It's fitted into the block. It's an oil pressure sensor. Had one on a smallblock I had. It was strangely used to control the power to my electric choke. Like a kill switch. If I had oil pressure the choke worked right. Unplugged it and the choke closed completely and car wouldn't start. All factory wiring on my new 78 Nova. Ya, I'm that old. LOL
Yeah JHolley was right, its for the dummy light (as the napa guy called it).
I picked up a tubing kit and I'll hook it up tonight. Let's hope there's no leaks up by the gauge.
#13 |
chrome makes it go FASTER!
If there is, you'll find out quick!
I like to use the two-man approach, one under hood, one in cab to watch for oil leaks and watch gauges.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
#14 |
wow... those first two pics looked like it was in the intake.
#15 |
![]() Join Date: Sep 2007
thats where my oil pressure guage line screws into
1967custom |
#16 |
Well I almost fixed it. That kit had 2 compression fittings and I screwed up both of them at the sending unit location so there's a little leak coming out the top of the fitting. The gauge side worked and went right in. Off to find some more fittings tomorrow. Thanks for the help fellas.
By the way, I was trying to see if the water temp sender was working so while the truck was running, I put the positive lead from my meter on the end of it and grounded the negative lead and got about 13 volts. So that means my temp sender is working right?
