NArrower rearend
hi does anyone know of a rearend thats 5x5 pattern but a couple inches narrower on each side than a stock 72 one like 2-3 inches total. maybe a 88-98 or even like a 95 caprice anyone ever done a swap like this rather then cut one down thanks for replys
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Re: NArrower rearend
I remember look at the flange numbers for a 72 Axle and a 96 Impala axle and the Impala being 2-3" bigger. But I think a earlier 67-69? Is a bit shorter but only a few inches. But don't quote me on that I could be wrong.....
Adam M STX Designs Motorcycles | Choppers | Hotrods |
So the impalas are wider i know the 69 rearend on a c10 is 1.5 inches narrower total i need that per side so 3 total
Superbad
We narrow the rear end housings at my work & use Dutchman
Motorsports steetable custom alloy race axles. Total cost should be around $500 - $600, depending on what it cost you the have the housing narrowed. |
You can find the 65 - 69 12 bolt rears at a junk yard.
I picked one up for about 150 then bought dutchman 5x5 axels for 300 from ECE. The flange to flange width is 56.5. They are 1.5 inches narrower that the 70.5-72 12bolts. Becareful not to buy the wrong one! I had to buy two. |
Happy to be here
![]() Join Date: Mar 2000
I believe the 2nd gen camaro axles are close to those dimensions. Since your going to have to buy axles, you could have set built or redrill those for 5x5.
