Old 09-04-2009, 08:22 AM   #1
sjarrett71
sjarrett71's Avatar
Auto Linkage Question
Teeitup has a truck he is parting on the parts board. It has a TH350 transmission. The trans I found for my truck is a TH400. My question is are the linkages for the transmissions the same? If they are different, what are the differences? Does anyone have pics to compare the two?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 09-04-2009, 10:04 AM   #2
redbaron69
redbaron69's Avatar
Re: Auto Linkage Question
not sure myself,bump for you
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 09-04-2009, 11:02 AM   #3
leddzepp
Moderator
leddzepp's Avatar
I don't think there is a difference in the transmission linkage on the 2WD trucks, whether it is a 350 or a 400. IIRC, the linkage is different if you have a 4WD truck. Someone will post a pic to verify, I am sure.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 09-04-2009, 12:07 PM   #4
71 super
71 super's Avatar
The pivot point on the frame is different and the 350 will not line up with the 400 trans unless you drill new holes in the frame. The rod and the connection between the trans and pivot are the same. The 4x4 uses a different pivot point and a different rod to connect.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-04-2009, 11:08 PM   #5
Classic Bowties
Always on the hunt...
Here are some side by side comparison pics for you to check out.
Classic Bowties is offline   Reply With Quote
