Old 09-04-2009, 10:01 AM   #1
tomlamb
New Project
While my 66 project is still in the works, I stumbled on this...
It has not driven since 1987 and I am not sure what way I am going to go with it yet.
tomlamb is offline   Reply With Quote
Old 09-04-2009, 10:30 AM   #2
63 & 64 Bowties
and a few others
Re: New Project
Nice score. Looks real solid. Is that 5 lug front and 6 lug rear?
If you search this section you'll find a bunch of S-10 swaps going on, and a few Mustang II projects.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-04-2009, 10:44 AM   #3
tomlamb
Re: New Project
It is 5 lug in front, not sure why as it has front drums that I think I heed to take the hub off to inspect the shoes so I have no idea what front it has. I think it is 5x4.75, but I am not sure...
Old 09-04-2009, 07:30 PM   #4
63 & 64 Bowties
and a few others
Re: New Project
Are you sure it's not a Camaro or Monte Carlo or something front clip? How close have you inspected it?
Old 09-04-2009, 08:35 PM   #5
tomlamb
Re: New Project
It is not a clip, it has a solid axel with king pins (I know because I just lubed the front end, man there are a lot of zerks) so I don't know what drums are up there. It has a large spring on the inner side of the drum if that helps...
Old 09-12-2009, 10:57 AM   #6
tomlamb
Re: New Project
I got it running and driving! New Tank, headlight wiring, tires, bulbs, window and wing glass, fuel pump, water pump, hoses, fluids, and rebuild the carb. I still have to figure out what I am going to do with it but at least it runs. I was a little suprised at how high the RPMs are doing 45 MPH, not sure I would want to try taking it on the so cal freeways...
Old 09-12-2009, 12:11 PM   #7
PDW HOTRODS
PDW HOTRODS's Avatar
Re: New Project
Front hubs are probably 53 Chevy car hubs.
PDW HOTRODS is offline   Reply With Quote
Old 09-12-2009, 02:38 PM   #8
tomlamb
Re: New Project
that sounds correct, I had to pull the hub off to check the shoes, it still had ball type bearings.
Old 09-12-2009, 05:25 PM   #9
CAL 58 GMC
CAL 58 GMC's Avatar
Re: New Project
Cool man! Welcome to the fat fender side!
CAL 58 GMC is offline   Reply With Quote
