Old 09-04-2009, 10:29 AM   #1
Alex1
Alex1's Avatar
1" vs 1.25" rotors
How does one know which one you have? is the only way to tell is to measure?
Alex1 is offline   Reply With Quote
Old 09-04-2009, 10:48 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 1" vs 1.25" rotors
Measure the thickness of the rotor. It's the only way to be sure.
Old 09-04-2009, 10:59 AM   #3
Damien
Damien's Avatar
The rotor should say the minimum thickness on it. A 1.25" rotor will have a min. thickness over 1". I think it says 1.20" or something.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 09-04-2009, 11:06 AM   #4
hessian18
Gen III Power
hessian18's Avatar
Once you have seen the difference in the two you can tell just by looking at them.
But your best bet is to measure them or like mentioned above check for minimum specs.
Bob
---Bob---
'81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon...
hessian18 is offline   Reply With Quote
Old 09-04-2009, 02:34 PM   #5
bigblock73
yeller
bigblock73's Avatar
If your truck is a pre 81, you likely have 1.25" rotors. The 1 inchers were more of an 80's thing.
bigblock73 is offline   Reply With Quote
Old 09-17-2009, 07:23 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
1" rotors were introduced in 1981 as the Low Drag rotors. Everything prior as Jeff pointed out are 1.25".
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
