Old 09-04-2009, 03:20 PM   #1
epashhans
epashhans's Avatar
Biggest 20" tires you are running?
I hate the little "rubber band" tires on 20" wheels...just curious what the biggest you can run or you guys are running, both front and back. This is for a 67 swb 2wd with a 3/5 drop. Any pics? I really appreciate it...
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 09-04-2009, 04:57 PM   #2
c10addict
c10addict's Avatar
Re: Biggest 20" tires you are running?
Im running a 255/50/20 on the rear of my 68... Pretty nice size sidewall
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 09-04-2009, 05:12 PM   #3
big_al_71
big_al_71's Avatar
295-40-20 on a 20x10 6 inch rear drop
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-04-2009, 06:48 PM   #4
Ackattack
Ackattack's Avatar
315/35/20
A little thin, but I wanted wide
Ackattack is offline   Reply With Quote
Old 09-04-2009, 06:51 PM   #5
Chevyman680063
Chevyman680063's Avatar
Addict and big_al, you both have beautiful trucks.
Chevyman680063 is offline   Reply With Quote
Old 09-04-2009, 08:33 PM   #6
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Originally Posted by Ackattack View Post
315/35/20
any chance you could get a pic of inside the hood area I want to see how it clears the ball joints and tie rod end??? I was looking at my rallies and I can't go in very much with offset beacuse of those things??? SO I'm just woundering what size rime I need to clear that stuff.....I have been keeping an eye on a deal on Craigslist and such so I need to know before I buy or try
also did you guys have to restud your drums to get your wheels on??
thanx
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-04-2009, 09:22 PM   #7
big_al_71
big_al_71's Avatar
Thank you!!!!!!!
Old 09-05-2009, 03:02 AM   #8
nuke1
nuke1's Avatar
front has 255/40/20 and rear is 295/45/20 one 9.5's wide rim
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 09-05-2009, 12:45 PM   #9
c10addict
c10addict's Avatar
Thanks Alot!!
Old 09-05-2009, 01:38 PM   #10
c10crazy
Like a Rock!
c10crazy's Avatar
Nice rims! Not to hijack- but could you guys also post a rear shot to show how wide those sizes are?.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 09-05-2009, 02:54 PM   #11
big_al_71
big_al_71's Avatar
Gere are some picts that kind of show how wide the tire is..these are the only ones I have in this computer..
Old 09-05-2009, 03:37 PM   #12
Hottrucks
Hottrucks's Avatar
285/50R20 will they fit I found a deal on craigslist hoping to score tomorrow....
Old 09-05-2009, 03:42 PM   #13
Puropedo
285/45/20s front 305/50/20s rears, same wheels/tires, different trucks.. (dont like rubber bands either )
Puropedo is offline   Reply With Quote
Old 09-05-2009, 03:46 PM   #14
Hottrucks
Hottrucks's Avatar
PUROPEDO....Any problems on your 70 with them??? upfront I have my truck bagged/notched and cupped...and just was woundering how the clearnce was??
Old 09-05-2009, 06:34 PM   #15
Puropedo
My front rim/tire set up on my 78 gmc and 72 cheyenne would not work for a bag suspension up front, (tires are too wide ) I have a static 4 inch drop and sometimes the tires rub on the wheel wells ( on my 78 gmc I had to take the fender wells off and cut the lips on the inside of the fenders it has a 5.5 front drop). For you my friend I would personally recomend 20x8.5 wheels with 5.5-6.5 backspacing and 245/45/20 tires up front, rear you can go as wide as 315 depending on your rear wheel backspacing. Here are a few pics of my 68 with 22s not bagged but will be in the future, I got such fat tall tires on the back that they are almost rubbing the front wheel opening (will fix that problem moving the trailing arm crossmember back about an inch.
Old 09-05-2009, 07:15 PM   #16
Hottrucks
Hottrucks's Avatar
well I missed the deal which is what I figured but at least the guy was nice enough to cal me back....
If you bag it the best you can hope for is a tire 29 1/2" tall with no wheel wells after that your into the inner fender support ...my 235/75/15's (29 1/2"s) will just clear my support by about [ ] that much also you start to run into heater box issues then hood hindges ( my LCA are cupped 2 3/4" it was easy and cheap I also used a stock monroe 5258 ( I think I can get # if you need it) shock it drives very well but I think I may mod the upper by putting a cut in it and flattening the ball joint...how ever it doesn't bind and no scrubline issues)
on the rear I have 31/10.5/15 with a 2 1/2" C notch and they rub at the top of the wheel well right where the tub meets the inner bed panel
these are on stock rallies
a smaller tire and I would drag the collectors off (they're alittle ummmmm worn now) so an exhaust mod woud have to be done ( inside the frame rail with dif headers) nice thing is I can drive it on the Bump stops if I had to??? like at the ice cream place
Old 09-05-2009, 08:10 PM   #17
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Puropedo
what is the drop on your yellow truck? also what size and BS on the wheels and tires? I wanna go 4/6 ECE with AR TTII's need to know what is the tallest/widest tire I can run and what BS I need to avoid any issues.
Thanks, Ron
-Ron-
OldSkool71 is offline   Reply With Quote
Old 09-05-2009, 09:54 PM   #18
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
285/50/20s all the way around on mine. No drop yet. I personally want to go lower profile but these were cheap so i got them
chevyguy_72 is offline   Reply With Quote
Old 09-05-2009, 11:04 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Originally Posted by Puropedo View Post
Here are a few pics of my 68...
Ahem.... '68, I don't recall you ever mentioning a '68 my friend.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-05-2009, 11:21 PM   #20
Hart_Rod
Hart_Rod's Avatar
What he said....how about more pictures....
Hart_Rod is offline   Reply With Quote
Old 09-06-2009, 12:37 AM   #21
epashhans
epashhans's Avatar
Hey chevyguy_72, can you post some pics of those tires/wheels on your truck? Thanks!
Old 09-06-2009, 12:41 AM   #22
chevyguy_72
Vintage Evil
I will have to take a new one tomorrow. They are the ones in my avatar but i can not find the original pic only the shrunk down one...
Old 09-06-2009, 04:43 AM   #23
Puropedo
Originally Posted by OldSkool71 View Post
Puropedo
Thanks, Ron
Ron, Youre on the right track, my cheyenne sports a 4-6 drop from ECE, wheels are AR TTII's fronts are 20x8.5s with a 4.5 backspace ( I recommend at least 5.5, I mest up on the measurements when I order my front ones but now I know, I will add an extra inch of bs later on to the front ones) rears are 20x10's with 5.5 backspace this worked out ok. Front tires are 285/45s and rears are 305/50s. I like that hot rod look Also, I think those tire sizes will be the max tall,wide you may use unless you do some mods to your truck.
Nate, my 68 was to be a surprise, besides I dont wanna seem like a show off ( having too many nice old trucks)
Funny how two TOTM winners ask for more pics of my 68.... Do you guys think I deserve that same badge on my avatar? I dont really mean to hijack Epanshhas thread but if you insist here is a teaser...
Old 09-06-2009, 08:47 PM   #24
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice teaser pic...
Can't wait to see what else you have in store for it. Now... what's that parked behind the '69?
-Nate
Old 09-06-2009, 08:48 PM   #25
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
[QUOTE=Puropedo;3504213]Ron, Youre on the right track, my cheyenne sports a 4-6 drop from ECE, wheels are AR TTII's fronts are 20x8.5s with a 4.5 backspace ( I recommend at least 5.5, I mest up on the measurements when I order my front ones but now I know, I will add an extra inch of bs later on to the front ones) rears are 20x10's with 5.5 backspace this worked out ok. Front tires are 285/45s and rears are 305/50s. I like that hot rod look Also, I think those tire sizes will be the max tall,wide you may use unless you do some mods to your truck.
Can you post some more pics of your Cheyenne? Or pm me and you can email them to me directly. Specifically around the wheels to get and idea of how they look setting in or out. Inside from underneath would be great to front and rear. When you get an opportunity of course sir..dont mean to hijack this thread but hopefully this will help others with the same questions as well. And im with you on the Hot Rod look as well. Thanks in advance.
-Ron-
