Old 09-04-2009, 05:00 PM   #1
3r!c84
Badass
3r!c84's Avatar
oil pressure
oil pressure .mines been running high like 40-60 is that bad?
a few weeks ago it was like 20-40
where sould it be at?
oh its a stock 305
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-05-2009, 08:34 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: oil pressure
anyone?
-00 Saturn 5spd
1/4:13:90
Old 09-05-2009, 09:47 PM   #3
jd74c-10
Re: oil pressure
have you recently changed oill or done anything else to the motor
jd74c-10 is offline   Reply With Quote
Old 09-05-2009, 09:53 PM   #4
3r!c84
Badass
3r!c84's Avatar
Re: oil pressure
nope
-00 Saturn 5spd
1/4:13:90
Old 09-06-2009, 10:22 PM   #5
jd74c-10
Re: oil pressure
40 to 60 pounds of pressure is not a problem, but if you only had 20 to 30 psi before. then something had to change somewhere. the filter has a bypass valve inside of it which could possibly stick shut and cause the pressure to change. also the oil pump has a pressure regulater valve that could be sticking. i have seen cam bearings spin in the block and cause the pressure to go up. your gauge could be acting up also. i would change the oil and filter and cut the filter open to check for metal. is your engine making any noise.
Old 09-06-2009, 10:29 PM   #6
3r!c84
Badass
3r!c84's Avatar
Re: oil pressure
no noises.like ticking or clickin.its been running good.ive been thinking the gauge was acking up.is there any way to check this? where is the oil pressure sensor?
-00 Saturn 5spd
1/4:13:90
Old 09-08-2009, 08:28 PM   #7
silverado_hotrod
Re: oil pressure
hey the oil pressuresending unit is located right behind the dist right at the rear edge of the intake on a sbc i dont know where it is at on other motors
silverado_hotrod is offline   Reply With Quote
Old 09-08-2009, 09:52 PM   #8
3r!c84
Badass
3r!c84's Avatar
Re: oil pressure
ok ill look tomorrow after school
-00 Saturn 5spd
1/4:13:90
Old 09-09-2009, 01:05 AM   #9
85Bowtie
85Bowtie's Avatar
Re: oil pressure
I'm sure your motor is fine, almost all chevy's I've seen do that.
A safe rule is 10 psi for every 1000 rpm. I drove my '68 Satellite with a 318 with NO oil pressure for 10-15 miles with absolutely no problems. Ended up doing a rebuild, but it was still mechanically fine.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 09-09-2009, 06:19 AM   #10
project_77
Re: oil pressure
did you change the type or weight of oil?
another thing to note,
it is not uncommon to see a sbc with 5-10psi at idle. on my 350, it runs about 45psi @ 3k.
at idle, it's 10-15psi.
project_77 is offline   Reply With Quote
Old 09-09-2009, 06:31 AM   #11
3r!c84
Badass
3r!c84's Avatar
Re: oil pressure
no its umm 10w30 or somthing (ill look after school today)
at start up its at like 20-30 and idling it says the same around 3-4k it gits up pritty high at 40-45.but just driving at 2100 its at 35
-00 Saturn 5spd
1/4:13:90
Old 09-09-2009, 06:45 AM   #12
project_77
Re: oil pressure
is that at cold start-up or warm start-up? oil pressure should be greater during a cold start-up.
Old 09-09-2009, 08:52 AM   #13
silverado_hotrod
Re: oil pressure
i know when my 86 chevy k10 with the 305 when its cold it pegs the gauge out till it gets warmed up like 10 mins then goes to about 45-50 pounds i use 10w-40
Old 09-09-2009, 09:41 AM   #14
jchav62
1962 C-10
jchav62's Avatar
Re: oil pressure
Your pressure is fine. Nothing to worry about. From the numbers your saying...and your not hearing any noises or differences, just keep driving.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
