Old 01-13-2003, 03:05 PM   #1
Dale DuBose
What fluid in NP203???
So what kind of fluid goes in this thing? I do have a part-time kit in it. Thanks.
I need all the help I can get.
Dale DuBose is offline   Reply With Quote
Old 01-13-2003, 03:56 PM   #2
Tuffold72
The service manual calls for 30W. If your running a part time kit, make sure you put it in 4x4 at least 1 time every to weeks and drive a few hundred feet. This puts oil back in the rear output shaft bearing area.
Tuffold72 is offline   Reply With Quote
Old 01-16-2003, 12:21 AM   #3
MJN
MJN's Avatar
my book says 10w40
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-16-2003, 04:09 AM   #4
79Silv4x4
Workaholic
79Silv4x4's Avatar
10W40 in mine too.
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 01-16-2003, 10:44 PM   #5
silvereagle1770
thats what the books say i run 80 90 in mine have been for 3 years hasent gave me no problems the oil just dont seem thick enough to me
79 4x4 short box
silvereagle1770 is offline   Reply With Quote
Old 01-21-2003, 03:36 AM   #6
wg77
30wt,40wt,80w90,it all works,throw some Lucas oil stabilizer in,that will make any gearbox work smooth.
wg77 is offline   Reply With Quote
Old 01-21-2003, 12:20 PM   #7
NAPCO ken
NAPCO ken's Avatar
203s all use 10W40. I have an NP205 in my 88 crewcab dually, and it uses ATF!!! I thought about putting gear oil in there instead, but that's what the factory put in, and they have just a tad bit more engineering experience than me, so I left the ATF in it.
ken
'58 Chev NAPCO 4x4 short
'60 GMC Suburban 4x4, restored
'60 GMC 3/4T stepside 4x4
'64 GMC Suburban 4x4, restored
'90 Chev Suburban 4x4, dually, ZZ502
'77 GMC Suburban 4x4, one ton axles, 12" lift, 39.5"s
'88 Chevy crewcab dually 4x4, 10" lift, 42"s (x6!)
'03 Jeep Wrangler Rubicon
'79 Chev 3/4 Suburban 4x4, 400-400-203
NAPCO ken is offline   Reply With Quote
Old 01-21-2003, 12:50 PM   #8
Mudder
Mudder's Avatar
10w40 in a 203
Mudder is offline   Reply With Quote
