Brothers front sway bar
Has anyone installed a brothers front sway bar on a 70 c-10? Did anyone use the tab that is supposed to be drilled into the lower control arm?
It'd be alot cooler if you did
Re: Brothers front sway bar
Anyone?
I thought those holes were in the control arm by default. They are on my 68' lowers.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
I went ahead with the install this weekend. I ended up drilling into the front of the LCA. Also, I needed to get a longer bolt that goes through the rod end link. I should have gone to the junk yard at got a 1 ton off of a donor truck.
Happy to be here
![]() Join Date: Mar 2000
Post some pics of your install please.
interested in the pix also,,i just purchased a sway bar from brothers and was wondering the same as you,,,will i need to drill into the lower control arm? let us know how it turns out,,,thanks..
68 C/10 short bed 77 C/20 silverado long bed 05 GMC Duramax Crew |
That sway bar is cheap ($99.00) compared to the musclebar from ART (400.00). I have the ART upper and lower control arms. Do you think it will work on them. I see you are running stock. I had to pull my stock swaybar when I went to the new control arms.
I have no idea if this will work with your setup. I know Nate at porterbuilt has a solution that will work for you, and his sway bar cost a lot less than $400 bones.
