09-05-2009, 10:39 AM | #1 |
looking for a 4 in. notch or so
I have a c notch already but I would like to find a deeper one,almost the whole side of the frame rail ,all I can find are the large step notches or any ideas or pics of home made ones.Is on a 78 blazer
09-05-2009, 10:48 AM | #2 |
Re: looking for a 4 in. notch or so
Porterbuilt can prob make you a custom notch per your specs. It would also be pretty easy to get one of the available step notches & just trim it down to the height you need (you'll just be trimming off alot more than the guy that needs the big notch).
09-05-2009, 11:12 AM | #3 |
its just $$$$$
09-08-2009, 04:44 PM | #4 |
How close is the diffenential to the tub and will a deeper notch cause interference?
09-08-2009, 11:04 PM | #5 |
You can have someone like Porterbuilt make you one, or if you can weld, you can make your own.
