09-05-2009, 10:42 AM | #1 |
Trying to ID the year model of brackets
I need assistance confirming the year range for these sbc OE brackets. Are they truck or car specific? Any help would be appreciated as these are what I'm looking for for a project. I need to find some.... the more I know about them, the easier it will make the search.
09-05-2009, 09:13 PM | #2 |
The Older Generation
Re: Trying to ID the year model of brackets
I will have to look closer at my Alt bracket but I'd say they are the same as the brackets on my '71 Chevy pickup with the 350. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-05-2009 at 09:13 PM. |
09-06-2009, 02:53 AM | #3 |
70 Chevrolet=Obsession
If you're talking about the alternator brackets, I have a 70 350 and those are exactly the same brackets that I have and mine are OE.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 09-06-2009 at 02:54 AM. |
09-06-2009, 12:55 PM | #4 | |
I will admit I've never really paid attention to the lower bracket & how it's shaped/looks. Ditto for the a/c set-up. Since I'm shooting for a 60's engine compartment (meaning no aftermarket set-up here), I think these would work well & keep the a/c on the pass side. I would also be able to add pwr steering since it was available too. I do not want any thing from later years though (where the alt bracket mounts off the pass head/top of the intake) as that's more of the 70's thru early 80's type of brackets. If you guys could put a pic up to confirm that would be great (I'll take your word regardless ). Do either of you have the same a/c bracket?
09-06-2009, 04:49 PM | #5 |
got to be 1970-1977 .
http://i648.photobucket.com/albums/u...Picture008.jpg |
09-06-2009, 06:19 PM | #6 |
71-72 maybe. I have a 74 & have seen under the hood of a 73 so I know those brackets are not 73-77 vintage.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-06-2009 at 06:20 PM. |
09-06-2009, 06:20 PM | #7 |
Watch out for your cornhole !
Scoti, they are 69-72 brackets for sure. What parts do you need ? I have a bunch of that stuff.
You can look in my blog to see pictures of the alternator and power steering brackets on my 327.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 09-06-2009 at 06:25 PM. |
09-06-2009, 06:28 PM | #8 | |
I also need some 'Chevrolet' script valve covers (w/o grommet holes & w/straight across fastener holes) .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-06-2009 at 06:29 PM. |
09-06-2009, 06:32 PM | #9 |
I've got all of the power steering and alternator brackets at my shop right now. Power steering pump too. No A/C stuff though. I also have the script valve covers.
You want me to get them out for you ?
09-06-2009, 06:41 PM | #10 | |
Still thinking about the spindles? We could work something out if so as I've got the tires off my steelies w/some initial clean-up done (one of them had fix-a-flat in it so you know what that does). I also have another set of ricer alum wheels needing some coating (friend of my x's). I figured I'd try & get out your way when we could co-ordinate our schedules. Satin blk on all the wheels & brackets....
09-06-2009, 06:45 PM | #11 |
I really need 73-87 drop spindles. I can buy them as cheap as I can buy 4 new ball joints and tie rod ends to go earlier spindles like you have.
I also need a bolt in c notch, a pair of 8 inch 5 lug steelies, any slot mags, whatever. You got any kind of trade stuff ? How soon you need the brackets coated and done ?
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 09-06-2009 at 06:45 PM. |
09-06-2009, 08:25 PM | #12 | |
What's a good timeline for you? *edit: I just noticed about the swap items that I neglected to address. I don't have anything you're needing but will keep the 'list' in my head as I'm constantly looking for stuff. If I come across the slots, I'm assuming 6's & 8's; w/6-lugs as the preference?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-06-2009 at 08:34 PM. |
09-06-2009, 09:52 PM | #13 |
6 lug or 5 lug, I have either option.
I can have the brackets cleaned and powdercoated by Thursday at the latest.
09-06-2009, 09:55 PM | #14 |
Sounds good.... shoot me a price including those v.covers you mentioned .
