09-05-2009, 01:51 PM | #1 |
please help
what is the differences in spindles between 67-72 and 73-87? will the spindles work with my control arms from my 67?
09-05-2009, 02:04 PM | #2 |
Re: please help
I mite be wrong but the lower ball joints are smaller on the 67-70 but you need to check an see I have a 71 frame but it already had disc brakes and the 73-87 spindles fit the old aframes ok
nickle and dime |
09-05-2009, 02:07 PM | #3 |
Re: please help
so if i hat a set of control arms from a 72, the spindles from a 73 should fit?
09-05-2009, 02:45 PM | #4 |
Watch out for your cornhole !
Re: please help
Your present controls arms are fine. You just need to install the later model ball joints into them. No mods needed to the arms.
09-05-2009, 04:15 PM | #5 |
Re: please help
thanks guys!! thats exactly what i kneeded to know, im so glad everyone on this site is so helpful!
09-06-2009, 03:30 PM | #6 |
67-72 parts collector,…
Re: please help
You will also need different outer tie rod ends.
09-06-2009, 08:40 PM | #7 |
Re: please help
Specifically, you want the outer tie rods based on the year of spindle used.
09-08-2009, 01:50 AM | #8 |
Re: please help
Classic Performance Products has everything you need to use the newer parts. I have 73 model spindles and brakes on my 63.
