Old 09-05-2009, 02:43 PM   #1
hittinseedz
hittinseedz's Avatar
late model seat
i want to put a late model seat in my 70 c-10. it has the factory bench right now. i want 60/40 with armrest or a fold down console seat. i would also like to keep factory seat belts. which seat would be easiest to install. if anyone has this kind of set-up please post pics, thanks
hittinseedz is offline   Reply With Quote
Old 09-05-2009, 02:49 PM   #2
Wideopenracing15
Wideopenracing15's Avatar
Re: late model seat
This may not be accurate but i heard you can put a fully manual 04-05? seat in. But it takes a little more modification. I know texandiot did one is his truck so you might want to talk to him
Wideopenracing15 is offline   Reply With Quote
Old 09-06-2009, 04:00 AM   #3
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: late model seat
Usually the biggest part of the job is fabricating the pedestals.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-06-2009, 12:19 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: late model seat
88-94 GM truck seat are nearly bolt in. No fabbing needed at all, just drilling new holes.
Old 09-06-2009, 01:51 PM   #5
DJMAN
DJMAN's Avatar
Re: late model seat
heres one.. http://67-72chevytrucks.com/vboard/s...d.php?t=361384
DJMAN is offline   Reply With Quote
Old 09-06-2009, 02:22 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: late model seat
There's a post on the 88-98 forum today with one in a 67-72 if you want to see how it looks.
Member Nr. 2770
Old 09-07-2009, 09:22 PM   #7
hittinseedz
Re: late model seat
thanks for the replies
Old 09-07-2009, 10:58 PM   #8
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: late model seat
Just about ANY GM truck/van seat out of the last 50 years is pretty much a "Drill-holes-bolt-seat" install. Even my '08 silverado seats (which are AWESOME. Lots of side support, thick cushions, big center console jump seat. But did use S10 seat belts but stock ones would work) were just a matter of drilling holes. Reason being is GM is cheap and makes the floor pans in all their trucks and vans flat. So there's no issue with funny angled seat mounts or anything.
I got REALLY lucky and got these for 100 bucks out of a rolled over '08 Silverado. Two tone, clean, and very comfortable. No matter what way you go, be sure to back all new bolt holes with backing plates or a pair of body washers per bolt. In my case it's a piece of 1/8in steel plate welded to the floor, with a body washer and lock nut on each bolt. Floor pans are weak, and just bolting with no structure is asking for them to rip out in a crash.
texanidiot25 is offline   Reply With Quote
Old 09-08-2009, 12:09 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: late model seat
not ALL gm trucks had a flat floor. there was a generation that spanned most of the 70's and most of the 80's that had a very UNflat floor.
Unless you are real skinny, you'll need to keep a close eye on the thickness of the seat back. One inch given up behind you feels like 2 inches of belly room lost.
On a totally personal note, but one worth mentioning... many feel the real tall seats sticking up into the rear window looks funny.
Old 09-08-2009, 09:54 AM   #10
jorgensensc
jorgensensc's Avatar
Re: late model seat
I agree with that guy
I actually have a perfect seat that is beautiful out of a 73-87 chevy truck. It won't mount right up, but I am considering using the seat brackets and tracks for our bench seat and seeing if I can make them work. I haven't truly decided if that's the way to go yet though. I may just sell the nice seat and do something else.
A agree with the seats sticking up through the back window. Really only looks good on a small back window '67, in my opinion.
Unless you take the headrest off AND get rid of the little holes in the top of the seat. But even then the newer seats then look like they are missing something. JMHO.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
