modifing a 73-87 tilt-colum on my 65
I have a tilt, automatic colum from a 76 c-10. I place it in the truck, attached it to the steering gear box and the colum is so long you can now steer the truck from inside the bed. Has anyone ever done this conversion before? Ideas?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: modifing a 73-87 tilt-colum on my 65
I haven't done it myself, but I know it has been done many times. It sounds to me like you need to shorten the intermediate shaft, That is the part between the end of the steering column and the steering box
![]() Join Date: Sep 2006
I am getting ready to do that myself, and I know I will have to modify the length and the housing diameter because it is larger around than the original one, but shouldn't be too tuff. I will likely eliminate the ignition wiring from it and just use the turn signals and hazards only. I wil try and post my progress on it soon.
If I shorten the intermidiate shaft then the shifter arm will be far away from the firewall. I think that will be a problem as well.
i used a 91 sub column there should be 2 plastic pins on the shaft under the inner fender drill them out and it will slide together.
65 c10 tore apart 70 c10 305/350th |
What chevy283 said - you can get the collapsible roll pins at NAPA to put back in the shaft after shortening - or, if you use the steering box from the same donor truck, the length should work fine - it did on mine (I used the entire front crossmember, power steering box and tilt column from an 83 on my 66; switched to B&M floor shifter)
#7 | |
51 Chevy 3100 Deluxe Cab(SOLD) ![]() 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD ![]() |
#8 | |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
