Old 09-05-2009, 09:17 PM   #1
1great68
defroster
I have an 85 K10 and i'm trying to get the defroster to work before winter.There is a vacuum line that comes out of the firewall right by the heater core that don't go to anything. I think that is the line for my defroster, but i don't know what to hook it to so i get vacuum? Please Help
1great68 is offline   Reply With Quote
Old 09-05-2009, 09:33 PM   #2
1great68
Re: defroster
I also noticed that the little white plastic piece on the flapper door is broken. Anyone know where i can get a new one?
Old 09-06-2009, 12:51 PM   #3
Sully Erna
Sully Erna's Avatar
Re: defroster
I have an Edelbrock 1406 and I hooked the line up to the passenger vacumm port. I do have an issue with it though. It barely blows unless I am on the gas. I havent figured if I am going to tap a new hole on top of the intake or somewhere else to pull full vacuum at idle. Hope this helps you.
Sully Erna is offline   Reply With Quote
Old 09-06-2009, 09:58 PM   #4
Prong
Re: defroster
I have a T fitting that splits off of the tranny's vacuum modulator line. Works fine for me.
Prong is offline   Reply With Quote
Old 11-04-2009, 11:15 AM   #5
Neon Beach
Re: defroster
I have the same defroster issue. Just followed the vacuum line thru the firewall right to a split vacuum line. Hopefully that is the issue.
Former vehicles:
1978 Camaro Z/28
1973 Camaro Type LT
1969 Camaro
1986 Chevy Wrangler
www.uvtalk.com
www.rustfreerides.com
www.talktimmins.com
"Cops already? What are we, beside a Krispy Kreme?
Neon Beach is offline   Reply With Quote
Old 11-05-2009, 09:14 AM   #6
billnorman
Re: defroster
My 85 has the cheap defroster, no air. Some enterprising mouses filled the plenum with mouse house stuff. With the fan on high if I rapidly switch between defrost and regular heat, it still occasionally spits chewed up cloth. You may care to vacuum yours out, I had to.
billnorman is offline   Reply With Quote
