09-05-2009, 09:58 PM | #1 |
Old Heap Driver
Heap Re-do, Pics
I’ve been busy the last several weeks doing a makeover on the Heap. I had been looking for a decent used comfortable dependable daily driver but couldn’t find what I wanted. I decided to spend what I had saved for a DD on the Heap and let it fill my needs. The process began back in July with the purchase of new front bumper, grill, hood, fenders, inner fenders, doors, door latches, cab corners, windshield, windshield and rear window rubber, outer door handles, window regulators, inner door handles, door weatherstrip, window run channel, carpet, door panels from RodDoors via Captkaos, and the rest was just old fashioned labor.
The paint is Hot Rod Black from Hot Rod Flatz, it’s a satin finish but almost has a pearl look to it depending on the angle. It’s very difficult to spray (IMO) because you’re limited to 2 wet coats. The natural reaction is to keep hitting areas to make sure you have good coverage, which causes the finish to vary. The color looks better in person. It’s kind of a bummer having real paint, now I have to dry the truck off after a washing. LOL. Replacing most of the body limited the amount of bodywork I had to complete. Believe me though, the bed more than made up for it. My air bag setup required the bed floor to be an inch and a half higher than stock. Six 2X4’s were bolted to the cross sills from side to side along with 2 additional 2X4’s across the middle of the floor area. He 2X4’s provided excellent support for the bed floor. The 2X4’s were hit with a really good coat of Thompson’s water seal. Since the 2X4 supports were going to be bolted over the sills and cover the bed mounting boltholes, another change had to be made. I welded carriage bolts to the sills from the top. This way all I had to do was go under the truck and slip on a nut and washer to each welded bolt. The bed floor was the simplest part of the Heap re-do. I went to Lowe’s and picked out a clean sheet of ¾” oak plywood and had them cut it to the needed length then into 12” wide boards. My bed measured out at 49.5 inches wide so I ended up with a gap between each board which was easily covered by the bed strips. The boards were test fitted then laid out on the garage floor and coated 3 times with Minwax clear. After everything was good and dry the boards were positioned in the bed and screwed down with new strips from Mar-K. I also purchased new side angle strips that were attached to the bedsides with bolts. I left a ¾” gap at the front of the bed to keep water from collecting on the floor. The interior is very simple, loop pile molded carpet, the same Chevy Cavalier seats I’ve had, a 2005 Cadillac DeVille center console, Rod Doors door panels covered with GM Ebony vinyl and Ostrich Emu, and of course the dash metal, steering column and steering wheel are coated in SPI orange single stage. The steering wheel is also accented with SPI single stage black. The cab wall is a combination of GM ebony vinyl and black loop pile carpet. Speaker panels from bigblock73 fill the corners. The 3-point seat belts are from Retro Belt. Oh, and my signature 37” shifter topped with a retro knob from Speed Dawg. A XM receiver fills the ashtray location. Future plans call for the dash to be filled with a speedometer and quad gauge from Dolphin Instruments. I’ll be using 3 3/8 speedo and the quad gauge will go where the factory fuel gauge is. The 4 gauge holes on the left will become the home for my air gauges. The Dolphin gauges are in the garage waiting on me to get started. I also need to replace the vent window rubber and have new door hinges in the garage that need to be installed. A new GM 290 HP 350 crate motor will be going under the hood soon. I can’t build a motor for what I can buy the crate for. A 700R4 will handle the gears. I’ll basically have a new truck without the payments or taxes. I’m also kicking around the idea of swapping out the heater/defroster for a Vintage Air system with AC. I’m sure I’ve forgotten some things but it’s been full speed every weekend since late June. My wife has been a very understanding woman the last couple months, why she has kept me the last 20 years is beyond me. Pics in the next post.............
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
09-05-2009, 10:00 PM | #2 |
Old Heap Driver
Re: Heap Re-do, Pics
Here ya go..........
09-05-2009, 10:02 PM | #3 |
Old Heap Driver
......and a few more............
09-05-2009, 10:03 PM | #4 |
Old Heap Driver
and finally, what to do with an un-used gas door..........
Yes, that's an air chuck. I have a 25 foot air hose and a tire repair kit i carry. Hey, ya never know.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. Last edited by S10Fan; 09-05-2009 at 10:30 PM. |
09-05-2009, 10:22 PM | #6 |
Old Heap Driver
Just a couple more.........
If anyone wants to know, the rear tires are 265/70/15 on 8" wheels. The Ostrich may end up on the cutting room floor, not sure if I like it.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. Last edited by S10Fan; 09-05-2009 at 10:24 PM. |
09-05-2009, 10:36 PM | #7 |
freakin AWESOME!!! I would LOVE to have a "heap" like that sitting in my driveway. Great job!!
09-05-2009, 10:49 PM | #8 |
Happy to be here
Dude! Where do I began? I have never been a big stepper fan, but I have always loved your truck. It has a great stance, and a look that just won't quit.
This refresh version is just that much better. The satin finish laid out nicely. I really hate that you changed the grill, but I gotta admit the new version looks good too. The Impala wheel fits your theme perfectly. I think the door panels look great too. I think the reason you don't care for the Ostrich, is it may be too much. It looks like you should cover the raised area around the door handle in the Ostrich and use some smoother on the bottom half. Either way, I freakin love what you have done....
09-06-2009, 12:28 AM | #9 |
I have car A.D.D.
The truck looks GREAT! I really liked the bed and the stance. All in all looks terrific.
Aren't wives amazing?
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
09-06-2009, 04:07 AM | #10 |
At the body shop.
The shifter needs a glitter knob. Dig the I-6 they sound sweet with a split manifold
09-06-2009, 09:05 AM | #11 |
makes me want to build a stepside. nice job
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
09-06-2009, 09:18 AM | #12 |
Great job, I love everything about it.
09-06-2009, 01:01 PM | #13 |
Slots go on anything!
Truck looks great, Bryan. Nice job!
09-06-2009, 01:18 PM | #14 |
That truck looks "B@D @$$".....
09-06-2009, 01:40 PM | #15 |
just WOW!!!
CHEVY ONLY |
09-06-2009, 04:47 PM | #16 |
Unfinished Project Club
Awesome job, great truck, great idea under the gas tank door Randy
Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas 1993 Jeep Cherokee. Looking for a swb chevy 73-87 Last edited by lvschevytrucks; 09-06-2009 at 04:48 PM. |
09-06-2009, 04:52 PM | #17 |
67-72 parts collector,…
Cool rehab of the Heap!
09-06-2009, 06:08 PM | #18 |
6.0 powered square
turned out great
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
09-06-2009, 07:48 PM | #19 |
Tot Roddin'
Awesome work on the 'ol Heap!
Do you have any more shots of the inline? Did you do anything special to the motor? What tranny? BTW... I love the air chuck and tire repair kit. Definitely handy when you need it.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-06-2009, 08:07 PM | #20 |
'87
Whoa! I really like it, the steering wheel and the shifter look awesome.
09-06-2009, 08:36 PM | #21 |
Love the impala wheel .
you are about to send me over the edge I have this extra 62 impala dash and steering wheel myself ....hmmmm Great looking truck MArk
the avatar was my 62 I owned for 27 years 84 chevy short short bed black 84 gmc long bed copper/ buckskin 88 chevy k5 blazer white Life's short make the most of it Mark aka impalmark |
09-06-2009, 09:26 PM | #22 |
All I can say is WOW! My favorite thing is the air hose, I had plans of doing that to my 77 but never got around to it.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
09-06-2009, 09:43 PM | #23 |
What a vision... every idea and detail compliments each other perfect!! If you would have just said what your were planning i dont think i could have pictured it all going together so well. Very incredible truck and awesome execution of not so ordinary details!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
09-06-2009, 10:37 PM | #24 |
Well thought out and put together.. There's nothing better than a slammed step side!
09-06-2009, 10:46 PM | #25 |
86 C10
i like it the shifter is sick
I have my parts to run a air chuck too but didnt know where to put it thanks for the idea
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
