09-06-2009, 10:54 AM | #1 |
Shorten Steering Column?
Greetings,
Is it possible to shorten or to find a steering column that is shorter for a 72'? We searched the forums but haven't found anything. We did find that many install a van tilt, but no metion of this being a shorter setup. MrBlue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
09-06-2009, 11:20 AM | #2 |
Re: Shorten Steering Column?
I'm going to do the same thing.The steering wheel is just to close for me w/ the stock setup.Both flaming river & ididit have universal fit columns in diff. lengths.If your looking to do it on a budget you could sink your column in 2",modify the mount & replace the intermidiate shaft
09-06-2009, 11:20 AM | #3 |
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I slid the stock column on my 72 Super forward about 1 1/2" to give you more "belly" room! I removed the steering shaft (from the column to the steering box) and drilled out the crash pins so the shaft would slide in easily. Then i dropped the coumn mount at the dash and slid it as far forward as i could before the shft indicator touched the gauge bezel and tightened it back up. It worked great..and gives you alot of extra room for a couple hours worth of work.
Down......with the sickness!! |
09-06-2009, 11:22 AM | #4 |
Cultural Infidel
It is possible to collapse the column an inch or two.
Check this thread, hope it helps. http://67-72chevytrucks.com/vboard/s...d.php?t=309895 -Mark
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold! It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
09-07-2009, 01:38 PM | #5 |
F.A.S.T. president
I have done the same to mine it was an easy mod.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
09-07-2009, 01:51 PM | #6 |
Is it possible to do this mod with a 3 speed manual column shift?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
09-07-2009, 01:54 PM | #7 |
Thread Killer!
I moved mine 3 inches, the hardest part of my conversion was moving the NS/backup switch up the column the same 3 inches, otherwise it would have been outside the firewall.
I don't have a big belly but I have long arms and I really like the extra room.
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... |
09-07-2009, 01:58 PM | #8 |
I did mine, but I didn't like it - for me, the steering wheel was too low, so I moved it back. But like everybody says, it's an easy and non-destructive mod.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
09-07-2009, 02:05 PM | #9 |
Just Not Low Enough!
i actually did mine yesterday in about an hour, was super simple.
ill upload the pic that helped me from another thread. where is says use the wood block DO IT!!! i found out the hard way and where it says heat the whole area and melt the 4 plastic plugs, i just drilled mine, since i have an az truck my rust is minimal. so the shafts werent rusted together.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
09-08-2009, 10:21 AM | #10 |
Can a guy shorten an automatic transmission column?
02-03-2010, 01:20 AM | #11 |
So, I was working on this mod in my truck this afternoon. One thing I found out is that the clamp, where the intermediate shaft meets the steering column... Well, the shaft isn't going to come apart unless you completely remove the bolt. There is a notch in the shaft the bolt fits in. Maybe a no-brainer for most of you guys, but had I known, it would have saved me at least an hour.
The idea to use the press to collapse the shaft was great. Especially if you don't want to wake up the neighbors. I knew that press would be good for something other than building AK's Still need to bolt it all together in the AM.. But, it seems to me there is a notch in the top of the steering column, and a widget on the column drop that fits into it. Do I need to lengthen the notch in the top of the steering column or is it okay to just bolt it all back together real tight? |
02-03-2010, 07:42 PM | #12 |
I did this the other day and with the notch on the top I just bent the tab that goes into the notch up and tightened it. I moved the neutral safety switch also. That wasn't too bad but I had to weld another tab for the switch to engage.
02-16-2010, 04:35 PM | #13 |
Can anyone chime in on whether or not this works with '72-87 square bodies?
02-16-2010, 05:18 PM | #14 |
its all about the +6 inches
why not go to the 73 - 87 board and ask them?
02-16-2010, 07:54 PM | #15 |
Try this thread.....was just reading it again earlier today.
http://67-72chevytrucks.com/vboard/s...d.php?t=191143 |
05-25-2011, 09:27 PM | #16 |
The thread for this is closed so I'll ask my question here. I'm looking at my truck with auto tranny and it looks to me like the linkage from the column to the transmission will be moved toward the front, putting it close to the vacuum booster for the brakes. Is there a conflict there?, and will I need to make changes to the linkage?
Thanks, Dan
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 |
05-26-2011, 11:40 PM | #17 |
nobody?
08-23-2013, 11:32 PM | #18 |
you ever figure that out? I have an automatic on the column id like to get a little more room with.
08-24-2013, 12:12 AM | #19 |
WOW, another thread from the past. I'm a big guy and can fit behind my stock wheel just fine. Can't imagine how large you need to be to have to shorten the steering shaft to be comfortable.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 08-24-2013 at 05:00 AM. Reason: Typo |
08-24-2013, 12:15 AM | #20 |
yea i like necroing old threads... Im 6'2" and my knees hurt and getting into the truck is what sucks. Im planning on getting different bench seat and moving it back since i removed the gas tank. But id like a couple more inches. (thats what she said)
08-24-2013, 12:19 AM | #21 |
Moderator
Some people are comfortable driving with their arms further extended, which is why I think they shorten the column. I have contemplated doing it just to see how I like it. I think Kevsclassics does it on a lot of his installations.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
