Got a question
I want to change my carb on my truck from this stupid quadrajet 750 to an edelbrock but im kinda dumb in this area, I hear that it depends on what type engine you got well I got a small block 305 in there that came with the truck, also its an 86 k-5 blazer full size 1/2 ton cause I know someone is gonna ask...
![]() ![]() Last edited by xodruxo; 09-06-2009 at 12:52 PM. Reason: typo |
Re: Got a question
what problems are you having with the q-jet. they are really good carb's when built and adjusted correct. as far as changing to a different type carb. what smog laws do you have where you live.you need to make sure you don't spend money then not be able to pass the smog check. if you don't have those worries you can adapt just about any carb to your motor, the edelbrock performer is a good trouble free carb. i use them all the time with no problems. on your truck the distributor and carb are both connected to the computer. if you change the carb you should change the distributor to a earlier hei unit and it should work fine. good luck
