Old 05-20-2002, 11:34 AM   #1
COBALT
COBALT's Avatar
Question TH400 leaking worse than ever...
So I'm going to drop it out and replace the front/rear main seals + drain fluid and replace filter and pan gasket. My question is what do I do about the converter?
I know the real leaking problem is coming from the front somewhere, but blow-back is covering the tranny with fluid every time I drive it, so I can only guess it's the front main seal.
The only way the converter could leak is if there was either a hole in the side of the converter, or where the main shaft from the tranny goes into the converter by the main seal, right?
How should I inspect the converter?
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
